Strange... Thanks for fixing!
investigated a bit more, the build fails reliably under the POSIX locale, e.g., if you export
LC_ALL=POSIX
before building.
The files built on the file system actually have the special chars replaced with ? in that case:
Inline image 1
The situation is a bit weird though in that trying to get the files with the actual name,
e.g., "/poëzie/café", makes Java actually return them and claim the file name is the
one passed in the constructor, to get the ? one has to use list() against the directory
so that the code actually reads the names from the file system.
And this is exactly what REST does to represent the directory in XML, it ends up
calling list(), resulting in the directory being properly encoded (because of the direct access
by name) but the files not (because it was actually read using list() from the file system).
I ended up setting up a working Assume by doing the opposite, checking that po?zie
is not there. This makes the test run with UTF locales, but be skipped with POSIX ones:
https://github.com/geoserver/geoserver/pull/1621
On Tue, May 24, 2016 at 4:15 PM, Andrea Aime <andrea.aime@anonymised.com <mailto:andrea.aime@anonymised.com>> wrote:
we have the master build failing on OpenJDK8 in restconfig due to
an apparent special char
management issue:
Tests run: 17, Failures: 1, Errors: 0, Skipped: 0, Time elapsed:
0.895 sec <<< FAILURE!
testSpecialCharacterNames(org.geoserver.rest.resources.ResourceTest)
Time elapsed: 16 sec <<< FAILURE!
junit.framework.ComparisonFailure:
expected:<...rce/po%C3%ABzie/caf%[C3%A9]> but
was:<...rce/po%C3%ABzie/caf%[3F]>
at junit.framework.Assert.assertEquals(Assert.java:100)
at junit.framework.Assert.assertEquals(Assert.java:107)
at
org.custommonkey.xmlunit.XMLAssert.assertXpathEvaluatesTo(XMLAssert.java:858)
http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/
I've tried locally and the test is not failing for me on openjdk 8.
Looking into it,it seems at least one char is "?" (%3F) so my
guess it that the code should
have Assume checks verifying that the underlying file system can
actually encode those
file names to start with
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
phone: +39 0584 962313 <tel:%2B39%200584%20962313>
fax: +39 0584 1660272 <tel:%2B39%200584%201660272>
mob: +39 339 8844549 <tel:%2B39%20%C2%A0339%208844549>
Le informazioni contenute in questo messaggio di posta elettronica
e/o nel/i file/s allegato/i sono da considerarsi strettamente
riservate. Il loro utilizzo è consentito esclusivamente al
destinatario del messaggio, per le finalità indicate nel messaggio
stesso. Qualora riceviate questo messaggio senza esserne il
destinatario, Vi preghiamo cortesemente di darcene notizia via
e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti,
copiarlo, od utilizzarlo per finalità diverse, costituisce
comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
The information in this message and/or attachments, is intended
solely for the attention and use of the named addressee(s) and may
be confidential or proprietary in nature or covered by the
provisions of privacy act (Legislative Decree June, 30 2003,
no.196 - Italy's New Data Protection Code).Any use not in accord
with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is
addressee(s). If you are not the intended recipient, please
contact immediately the sender by telephone, fax or e-mail and
delete the information in this message that has been received in
error. The sender does not give any warranty or accept liability
as the content, accuracy or completeness of sent messages and
accepts no responsibility for changes made after they were sent or
for other risks which arise as a result of e-mail transmission,
viruses, etc.
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
