I believe this is because the build was started before the dependant geotools patch was pulled.
I think because nothing changed since then on the GS repo, hudson didn't start a new build.
Can you force it to try and build again? I am quite certain it would be solved then.
Niels
On 03/09/13 02:20, Jody Garnett wrote:
During last nights meeting Andrea tried out a CSW pull request on master (before applying it to 2.4.x).
As a result CSW is currently failing:
Failed tests: testGetSingle(org.geoserver.csw.GetRepositoryItemTest): expected:<application/xml> but was:<null>
