[Geoserver-devel] master now using GWC 1.5-SNAPSHOT, geowebcache-master missing, build failing
In this merge, Kevin changed gwc.version to 1.5-SNAPSHOT:
https://github.com/geoserver/geoserver/pull/249
https://jira.codehaus.org/browse/GEOS-4978
Welcome back, Kevin!
There are a few things we need to be aware of:
(1) We really need a GWC release or a milestone for the upcoming GeoServer 2.4-beta.
(2) OpenGeo Hudson geowebcache-master is missing, so there is no GWC 1.5-SNAPSHOT on repo.opengeo.org:
http://repo.opengeo.org/org/geowebcache/geowebcache/
This causes the build to fail. I do not know where OpenGeo Hudson is getting its GWC 1.5-SNAPSHOT, but it is not being published on repo.opengeo.org .
Justin, do you know what happened to geowebcache-master?
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
On Mon, Jul 15, 2013 at 7:49 PM, Ben Caradoc-Davies <
GeoServer 2.4-beta.
Yup, kevin or jody will be doing a corresponding gwc beta for this
release. And in general moving forward we plan to do a gwc release for
every geoserver release the same way we do with geotools.
Odd.... not sure what happened there. I swear it was there yesterday :slight_smile: And
indeed there is a 1.5-SNAPSHOT in the local repo dated early this morning
my time. Odd. Anyways, job added back in.
repo.opengeo.org .
Kind regards,
Software Engineer
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
    1.5-SNAPSHOT on repo.opengeo.org <http://repo.opengeo.org>:
And indeed there is a 1.5-SNAPSHOT in the local repo dated early this
morning my time. Odd. Anyways, job added back in.
Thanks! I can confirm that the GWC artifacts are now present on repo.opengeo.org .
Kind regards,
Software Engineer
