[Geoserver-devel] Maven build error in WFS module
Hi Geoserver dev’s,
I sat down for a hack on GeoServer this evening and am running up against a brick wall while attempting to build with maven.
I am following http://docs.geoserver.org/stable/en/developer/quickstart/index.html
yet when a ‘mvn clean install’ from geoserver/src is attempted, I am getting a failure in
geoserver/src/wfs/src/main/java/org/geoserver/wfs/kvp/BBoxKvpParser.java with an
Unknown Symbol error on class ReferencedEnvelope3D from package org.geotools.geometry.jts
I’m wondering if there’s a missing geotools maven dependency?
Only other thing I can think of is I’m using maven 3.x rather then 2.1.x
Is someone able to test and/or give me a hint?
Sev
“We are dreamers, shapers, singers and makers…”
That class was recently added to geotools master; try and force a refresh or build geotools locally.
Jody Garnett
On 20/08/2012, at 10:40 PM, “Severin (aka Cliff)” <djseverin@anonymised.com> wrote:
Hi Geoserver dev’s,
Sev
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
Geoserver-devel mailing list
I just ran into this as well (and “forcing a refresh” via mvn -U install doesn’t resolve the issue.)
I would schedule a Hudson build to put the new jars into the maven repo, but apparently the build for geotools master is failing in Hudson right now. It looks like this error is not a problem with your local configuration though - probably we’ll have it sorted out in time for your next evening hack.
FWIW, a local ‘mvn install -DskipTests’ of GeoTools completed in a couple of minutes and got GeoServer back on track.
David Winslow
OpenGeo - http://opengeo.org/
On Mon, Aug 20, 2012 at 8:44 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Hi Geoserver dev’s,
Sev
geotools-master was broken by an intermittent wfs-ng failure that I have seen elsewhere from time to time. This caused Niels' 3D changes to not be published to the repo.
Failed tests: testGetFeatureLockingExpire(org.geotools.data.wfs.integration.MemoryDataStoreIntegrationTest): fid-3c6d8b2_13943566ad6_-7f74 not locked
I have created a Jira issue:
https://jira.codehaus.org/browse/GEOT-4234
Kind regards,
Ben.
On 20/08/12 21:11, David Winslow wrote:
I just ran into this as well (and "forcing a refresh" via mvn -U install
doesn't resolve the issue.)
configuration though - probably we'll have it sorted out in time for
FWIW, a local 'mvn install -DskipTests' of GeoTools completed in a
David Winslow
    Jody Garnett
    On 20/08/2012, at 10:40 PM, "Severin (aka Cliff)"
    <djseverin@anonymised.com <mailto:djseverin@anonymised.com>> wrote:
    Hi Geoserver dev's,
    I am following
    yet when a 'mvn clean install' from geoserver/src is attempted, I
    with an
    I'm wondering if there's a missing geotools maven dependency?
    Only other thing I can think of is I'm using maven 3.x rather then
    2.1.x
      Sev
    "We are dreamers, shapers, singers and makers..."
    Exclusive live event will cover all the ways today's security and
    Discussions
    malware
    <mailto:Geoserver-devel@lists.sourceforge.net>
    Discussions
    malware
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
And I kicked Hudson geotool-master for good measure. Once the artifacts are deployed, geoserver should build cleanly.
Failed tests:
Kind regards,
Ben.
David Winslow
    Jody Garnett
    Hi Geoserver dev's,
    I am following
    with an
    2.1.x
      Sev
    Discussions
    malware
    Discussions
    malware
Software Engineer
