Hmmm... never thought about spaces in path names throwing it off... quite possibly. we should update the quickstart to include quotes around the path names.
I suggest you use the first alternative for debugging from eclipse... its a lot easier then the one you are trying... All you have to do is find org.mortbay.jetty.Start in the "web" module... and run it as a java application from eclipse.
However... I believe the problem here is that you need to (from the command line) run "mvn clean install" from the root of the source tree.
Hmmm... I don't think so... the jars its trying to download are ones that will be installed in your local repo after you successfully to mvn clean install.
Subversion only stores the source code... and does not store any of hte libraries that geoserver depends on. If we did the size of our source repository would become huge... So maven allows to declare dependencies on third party libraries and projects and worries about storing them locally... handling versions... etc...
cheers,
Tom
[INFO] Scanning for projects...
[INFO] Searching repository for plugin with prefix: 'jetty'.
[INFO] org.apache.maven.plugins: checking for updates from mortbay-repo
[INFO] org.codehaus.mojo: checking for updates from mortbay-repo
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT: checking for updates from mortbay-repo
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-surefire-plugin: checking for updates from mortbay-repo
[INFO] artifact org.codehaus.mojo:cobertura-maven-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-eclipse-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-jar-plugin: checking for updates from mortbay-repo
[INFO] ----------------------------------------------------------------------------
[INFO] Building Web Application Module
[INFO] task-segment: [jetty:run]
[INFO] Preparing jetty:run
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from mortbay-repo
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geoserver:platform:1.6-SNAPSHOT: checking for updates from refractions
[WARNING] repository metadata for: 'snapshot org.geoserver:platform:1.6-SNAPSHOT' could not be retrieved from repository: refractions due to an error: Error transferring file
[INFO] Repository 'refractions' will be blacklisted
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geoserver:wcs:jar:1.6-SNAPSHOT
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=org.geoserver -DartifactId=wcs \
-Dversion=1.6-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there: mvn deploy:deploy-file -DgroupId=org.geoserver -DartifactId=wcs \
-Dversion=1.6-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file \
-Durl=[url] -DrepositoryId=[id]
Path to dependency:
1) org.geoserver:web:jar:1.6-SNAPSHOT
2) org.geoserver:wcs:jar:1.6-SNAPSHOT
2) org.geoserver:validation:jar:1.6-SNAPSHOT
mvn install:install-file -DgroupId=org.geoserver -DartifactId=validation \
Alternatively, if you host your own repository you can deploy the file there: mvn deploy:deploy-file -DgroupId= org.geoserver -DartifactId=validation \
Path to dependency:
3) org.geoserver:wfsv:jar:1.6-SNAPSHOT
mvn install:install-file -DgroupId=org.geoserver -DartifactId=wfsv \
Alternatively, if you host your own repository you can deploy the file there: mvn deploy:deploy-file -DgroupId=org.geoserver -DartifactId=wfsv \
Path to dependency:
2) org.geoserver:wfsv:jar:1.6-SNAPSHOT
4) org.geoserver:wms:jar:1.6-SNAPSHOT
mvn install:install-file -DgroupId= org.geoserver -DartifactId=wms \
Alternatively, if you host your own repository you can deploy the file there: mvn deploy:deploy-file -DgroupId=org.geoserver -DartifactId=wms \
Path to dependency:
2) org.geoserver:wms:jar:1.6-SNAPSHOT
5) org.geoserver:wfs:jar:1.6-SNAPSHOT
mvn install:install-file -DgroupId=org.geoserver -DartifactId=wfs \
Alternatively, if you host your own repository you can deploy the file there: mvn deploy:deploy-file -DgroupId= org.geoserver -DartifactId=wfs \
Path to dependency:
2) org.geoserver:wfs:jar:1.6-SNAPSHOT
6) org.geoserver:platform:jar:1.6-SNAPSHOT
mvn install:install-file -DgroupId=org.geoserver -DartifactId=platform \
Alternatively, if you host your own repository you can deploy the file there: mvn deploy:deploy-file -DgroupId= org.geoserver -DartifactId=platform \
Path to dependency:
2) org.geoserver:platform:jar:1.6-SNAPSHOT
7) org.geoserver:data:jar:1.6-SNAPSHOT
mvn install:install-file -DgroupId=org.geoserver -DartifactId=data \
Alternatively, if you host your own repository you can deploy the file there: mvn deploy:deploy-file -DgroupId= org.geoserver -DartifactId=data \
Path to dependency:
2) org.geoserver:data:jar:1.6-SNAPSHOT
8) org.geoserver:main:jar:1.6-SNAPSHOT
mvn install:install-file -DgroupId=org.geoserver -DartifactId=main \
Alternatively, if you host your own repository you can deploy the file there: mvn deploy:deploy-file -DgroupId= org.geoserver -DartifactId=main \
Path to dependency:
2) org.geoserver:main:jar:1.6-SNAPSHOT
8 required artifacts are missing.
for artifact:
from the specified remote repositories:
espace (http://maven.espace.ird.nc),
geotools ( http://maven.geotools.fr/repository/),
mortbay (http://www.mortbay.org/maven2/release),
refractions (http://lists.refractions.net/m2/),
Sateh (http://maven.sateh.com/repository),
central (http://repo1.maven.org/maven2),
ibiblio ( http://www.ibiblio.org/maven2)
[INFO] Total time: 3 minutes 32 seconds
[INFO] Finished at: Mon Jul 30 11:24:38 BST 2007
[INFO] Final Memory: 10M/18M
On 7/30/07, *Justin Deoliveira * <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
Hi Tom,
Looks like you are making progress!! Responses inline.
Tom (JDi Solutions) wrote:
> Justin,
> Spot on, thanks. Now I've got as far as importing the project
into Eclipse
> but there are loads of errors and it says in the docs "If your
eclipse
> projects are filled with errors, it may be that you either did
not set up
> Eclipse properly, or that you did not fully build Geoserver before
> attempting to setup the Eclipse projects. Go back and look again
in the
> prerequisites section."
> after I got mvn compile running in the correct directory it
managed to build
> successfully on about the 4th attempt. I then ran
> mvn -DdownloadSources=true eclipse:eclipse
> as per instructions and got the following:
> [INFO]
> [INFO] Reactor Summary:
> [INFO]
> [INFO] GeoServer .............................................
SUCCESS [
> 47.828s]
> [INFO] GeoServer Maven Plugins ...............................
SUCCESS [
> 0.016s]
> [INFO] Plugins configuration files ...........................
SUCCESS [6:
> 13.641
> s]
> [INFO] Configuration Deployment PlugIn .......................
SUCCESS [1:
> 32.687
> s]
> [INFO] Core Platform Module ..................................
SUCCESS [
> 0.094s]
> [INFO] Data Module ...........................................
SUCCESS [
> 0.125s]
> [INFO] Open Web Service Model ................................
SUCCESS [
> 0.078s]
> [INFO] Open Web Service Module ...............................
SUCCESS [
> 0.453s]
> [INFO] Main Module ...........................................
SUCCESS [
> 0.547s]
> [INFO] Web Coverage Service Module ...........................
SUCCESS [
> 0.469s]
> [INFO] Validation Module .....................................
SUCCESS [
> 0.312s]
> [INFO] Web Feature Service Model .............................
SUCCESS [
> 0.063s]
> [INFO] Web Feature Service Module ............................
SUCCESS [
> 0.484s]
> [INFO] Versioning Web Feature Service Model ..................
SUCCESS [
> 0.078s]
> [INFO] Versioned Web Feature Service Module ..................
SUCCESS [
> 0.422s]
> [INFO] Web Map Service Module ................................
SUCCESS [
> 0.453s]
> [INFO] Web Application Module ................................
SUCCESS [21:
> 41.45
> 3s]
> [INFO] Test Module ...........................................
SUCCESS [
> 0.297s]
> [INFO]
> [INFO]
> [INFO] BUILD SUCCESSFUL
> [INFO]
> [INFO] Total time: 30 minutes 23 seconds
> [INFO] Finished at: Sun Jul 29 22:10:28 BST 2007
> [INFO] Final Memory: 20M/36M
> [INFO]
> C:\geoserverdev\geoserver>
> ...after a load of files downloaded so that looks like it worked
ok right?
> So why do I have errors? I also followed the instructions
running a debug
> session but obviously that failed because of the errors.
> I did download a few plugins for Eclipse after I installed it but
other than
> that I haven't actually done anything else with it so I'm not
sure I can
> have set that up wrong?
Hmmm... looks ok. Did you set the M2_REPO classpath variable in eclipse?
It should probably be a bit more clear in the docs. It is explained
here:
http://docs.codehaus.org/display/GEOSDOC/5+Eclipse
Also... another thing to note which is a gotcha if you are not used to
working with maven and eclipse... is that whenever you run a command
from the command line it is important to "Refresh" all the projects in
your eclipse workspace. For instnace when you do an 'svn update' or when
you run 'mvn eclipse:eclipse'.
> Also, 2 other questions, Jetty is a java web server, is that
included in the
> geoserver build?
Yes. There is a class in the "web" module that will fire up a jetty
instance running geoserver. Its called 'org.mortbay.jetty.Start'.
> Does the build include datastores? Specifically I want to be
able to test
> with the Oracle datastore.
It includes some... but oracle is not one of them. If you look in the
pom.xml file in the "web" module you should see the following
dependency:
<dependency>
<groupId>org.geotools</groupId>
<artifactId>gt2-postgis</artifactId>
</dependency>
Directly after it add the following dependency:
<dependency>
<artifactId>gt2-oracle-spatial</artifactId>
<version>2.4-SNAPSHOT</version>
</dependency>
Be sure that after you do this you run mvn eclipse:eclipse again (from
the root of the source tree) and then refresh inside of eclipse (or the
new dependency wont be picked up).
> and, assuming I eventually get this running, is it possible to
get this
> build using my existing data directory so I don't have to setup
all the
> feature types again?
Yup. The easiest way to do this when running from eclipse is to set
GEOSERVER_DATA_DIR as a program argument.
-DGEOSERVER_DATA_DIR=<path to your data dir>
I added some docs to the end of the quickstart about this with a
screenshot.
-Justin
> cheers,
> Tom
> On 7/29/07, Justin Deoliveira <jdeolive@anonymised.com
>> Hi Tom,
>>> Hi all,
>>> So I notice there's no Oracle maintainer at the moment, Andrea
is on
>>> holiday and I'd like to help if I can (especially to investigate
>>> performance issues). I have a little java experience but have
never
>>> used Maven, Eclipse or subversion and tbh don't really fully
understand
>>> the role of all of them so this may be a bad idea but...
>> Glad to see you jumping into development Tom. I is always nice
to see
>> people getting down and dirty. Here is a quick rundown:
>> Subversion: version control system, getting code in and out of
central
>> versioning repository
>> Maven: build system, manages dependencies among geoserver
modules and on
>> third party libraries, allows for compling, testing, releasing,
etc...
>> Eclipse: most popular ide used by geoserver developers. maven
comes with
>> direct support for eclipse which makes it the most logical choice
>> From the error it just looks like you are not running the
command from
>> the root of the *source* tree. The root of the source tree should
>> contain directories called "main", "wfs","wms", etc... and most
>> importantly a file called " pom.xml".
>> My guess is that your "geoserverdev" directory contains two
directories
>> named "configuration" and "geoserver"? Just change directory to
>> "geoserver" and run the command again.
>> Also feel free to hop on IRC and ask for help directly. We will
be happy
>> to help you get setup.
>> -Justin
>> Justin Deoliveira
>> The Open Planning Project
>> http://topp.openplans.org
Justin Deoliveira
!DSPAM:4007,46adbe04127847180515871!
