[Geoserver-devel] maven compile error: gt2-xmlcodegen
I'm trying to build the geotools trunk with maven 2.0.6, but i receive
a build error, something like:
[BUILD ERROR]org.geotools.maven:gt2.xmlcodegen; plugin missing or of
an invalid version
I've take a look at the org.geotools.maven:gt2-xmlcodegen folder in my
m2-repo, and contains only a file called maven-metadata-central.xml
<?xml version="1.0" encoding="UTF-8"?><metadata>
  <groupId>org.geotools.maven</groupId>
  <artifactId>gt2-xmlcodegen</artifactId>
</metadata>
I've tried to copy manually the 2.5-SNAPSHOT and the 2.4-SNAPSHOT from
http://maven.geotools.fr/repository/org/geotools/maven/gt2-xmlcodegen/
but nothing changes :frowning:
Any suggestions?
an invalid version
</metadata>
Any suggestions?
Hum, where are you starting the build from? The root, or from modules?
The sources for that plugin are in build/maven, if you build from
the root it should be included in the build and compiled before
any other modules needing it.
I've launched the mvn compile from geotools trunk root
build/maven?
no folder like this in my repository... maybe I've forget some steps
(but I've read the developer guide...)?
build/maven?
you should have them in your geotools checkout, here is the root
a trunk checkout:
http://svn.geotools.org/geotools/trunk/gt/
a trunk checkout:
I try to obtain the trunk, but it's unclear for me how to use this...
i must build geotools and then copy the xmlcodegen in maven
repository?
Sorry, I'm a maven newbie, but the geoserver build tutorial not talks
about it... :frowning:
a trunk checkout:
repository?
If you build from the geotools checkout all modules should be
compiled, tested, packaged in jars and saved into the repository.
That includes xmlcodegen.
OK thanks a lot, i try as soon as possible.
Exactly the same error appears when i try to build GeoTools trunk :frowning:
View this message in context: http://www.nabble.com/maven-compile-error%3A-gt2-xmlcodegen-tp14620399p14645882.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Sigh... ci deve essere qualche circolarità nella build dei geotools
per cui solo chi ha già i jar nel suo repo locale riesce a fare
la build (e nessuns svilupattore se ne accorge, ovviamente).
Cosa succede se prima vai in build/maven, fai "mvn clean install" li,
e poi torni sulla radice e fai la build completa?
Ciao
mvn clean install on build\maven folder is completed successfully,
then also mvn compile is built successfully :slight_smile:
Now i try to build geoserver...
thanks in any case for support :wink:
P.S: Ma sei italiano? Se non sei italiano, lo scrivi veramente bene :slight_smile:
Geoserver also is compiled correctly.
mvn install fails due to some tests that fails (it's perfectly
acceptable in a trunk), i could search for a mvn command to disable
tests...
tests...
mvn clean install -Dmaven.test.skip
Ciao Kappu
Nice to hear that, and sorry for writing in Italian on a english
ml, I thought the message was a private one...
Certo che sono italiano, sto nella buca (la bassa, come la chiamano
qui) fra Mantova, Modena e Reggio Emilia.
Ciao
che sfiga :slight_smile:
Ciao
Defy all challenges. Microsoft(R) Visual Studio 2005.
Geoserver-devel mailing list
Eng. Simone Giannecchini
President /CEO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
