[Geoserver-devel] Maven issue?
I'm trying to stand up Geoserver with the WPS extension. I checked
out the 1.7.x branch (per the directions on the wiki) and then I
execute:
mvn compile -Pwps
It complains that wps isn't activated as a profile. Any pointers?
Joe
execute:
mvn compile -Pwps
wps on 1.7.x is old and unmaintained. On trunk there is an
improved version but even that one is still a work in progress,
with no funding behind it. I worked on it for some time,
then lost enthusiasm and have let it linger since December.
Would be nice to go back to work on it... unfortunately
atm I have higher priority stuff to attend to, without explicit
funding to get real work time on it I won't be able to
get a working WPS anytime soon.
Anyways, if you want to get your feet wet checkout trunk
and have a look at the current state of play in
src/community/wps
Andrea Aime
OpenGeo - http://opengeo.org
execute:
mvn compile -Pwps
src/community/wps
That said, the "-P wps" should work ok on trunk.
Justin Deoliveira
Looks like it - I ran into one dependency failure. I'll revisit later
today and let you know.
On Thu, Apr 23, 2009 at 11:24 AM, Justin Deoliveira
execute:
mvn compile -Pwps
src/community/wps
Justin Deoliveira
That could be due to the fact that the wps module in geoserver depends on some unsupported modules in geotools that are not regularly built. The best way to get those is probably to build geotools locally from svn and use the "all" property:
mvn clean install -Dall -DskipTests
The skipTests will prevent a lot of the unsupported tests being run which will result in a very long running build.
-Justin
execute:
mvn compile -Pwps
src/community/wps
Justin Deoliveira
Justin Deoliveira
I fear that I might left the module in a state where it depends on
Sextante jars, with them not being deployed anywhere. At the time no one
was interested in helping out so I did not care much about that.
Andrea Aime
Nah, the sextante related changes are still uncommitted in the
backup of my old disk. The reason it does not compile it's just
a useless dependency which I removed.
Now it compiles, but tests do not pass because it's looking
for Spring application context entries that are not more there.
I'll have a look and see if I can bring it up and building in
the weekend. Beyond that, well, I hope Joe can provide some
help in developing it further :wink:
Andrea Aime
I tried that maven build and I'm not getting a resulting WAR file -
can you verify the steps to generate so I can test where the WPS code
stands?
"all" property:
Andrea Aime
hi Joe,
You are on trunk? At the moment you need to use the "web2" profile. So the build command becomes:
mvn clean install -P web2
After which in the community/web2/web-app/target directory you should see a geoserver.war file.
-Justin
stands?
"all" property:
Andrea Aime
Justin Deoliveira
I'm on the trunk and I execute that and I get:
[INFO] [site:attach-descriptor]
Downloading: http://repo.opengeo.org//org/geotools/geotools/2.6-SNAPSHOT/geotool
s-2.6-SNAPSHOT.pom
[ERROR] BUILD ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geotools:modules:pom:null
Reason: Cannot find parent: org.geotools:geotools for project: org.geotools:modu
les:pom:null for project org.geotools:modules:pom:null
[INFO] Total time: 4 seconds
[INFO] Finished at: Thu May 14 08:08:49 EDT 2009
[INFO] Final Memory: 15M/29M
Is the trunk not stable? If so, is there a stable release with WPS
support that I could download?
Joe
On Wed, May 13, 2009 at 1:48 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
hi Joe,
geoserver.war file.
-Justin
stands?
on
best
the
"all" property:
which
Andrea Aime
Justin Deoliveira
We ran out of disk space during the build this morning, it looks like the automatic deploy was incomplete. Please try again?
-Arne
s-2.6-SNAPSHOT.pom
[ERROR] BUILD ERROR
Joe
Arne Kepp
