[Geoserver-devel] Maven Quickstart
The doc below is ready for review. Whoever is doing review please go ahead..
http://docs.codehaus.org/display/GEOSDEV/2+Maven+Quickstart
Kind Regards
Clint Lewis
Clint Lewis ha scritto:
I find two things a little funny:
* install does the testing as well... better put the section about testing before
   the one about deploying
* deploy seems to me the wrong term, since it does not deploy anything at all,
   just builds the output jars and installs them into the local repository.
   I would call it "building" (in the full meaning of the term).
Morever, are you sure that mvn compile does work if you haven't previoulsy installed
the jars? Try to wipe out geoserver from your local repository and do a mnv compile.
My gut feeling is that it won't work.
Finally, you miss mvn site to build the docs.
Wow thanks Andrea talk about speedy service.. I think my keyboard is still warm from typing the mail :wink:
Kind Regards
Clint Lewis
Not sure this is required since it is a quickstart. The fact that tests are running on an install sholdn't throw anythign off. I think that someone checking out for the first time will be less interested in runnign the tests standalone.
I agree, these are poorly named. And +1 for changing the term to building to mean compile + install.
You should be able to compile from scratch from the root. If you try to compile a spdecific module it will fail because it will be missing the parent pom from the repository. Definitley something worth noting. Good catch.
The build isn't configured to do a site build. The javadocs are generated with the javadoc:javadoc goal alone. However, I have a question. Can the site plugin merge all the javadocs together. One of the problems is that the generated javadocs are just local to specific modules and need to merged after the fact. Be interesting to find out.
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
!DSPAM:1004,44aa7569219161336712104!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Kind Regards
Clint Lewis
Justin Deoliveira wrote:
So I will remove the test!!
Cool I will rename the term now problem
Justin is write you cant compile a module from scratch but if you compile from the root you wont have problems. I will make a note of this in the docs?
What should I do here???
It will generate the standard site then, with the basic reports
It can, sure, just add the aggregate option. The only problem is that
I stumbled in a bug that triggers only during aggregation when you use
annotation in source, and happens to be a javadoc bug: http://bugs.sun.com/bugdatabase/view_bug.do?bug_id=6442982
Anyway, since I don't have anything to do, I'll update the build
to generate a site similar to the geotools one.
There is now two build sections for mvn compile and mvn install please see site, they should be renamed separately!
Kind Regards
Clint Lewis
I have updated the docs to reflect some of the changes that we discussed, please review and let me know. I will chat to you all later..
Done none of the mvn site stuff mentioned.
Kind Regards
Clint Lewis
