[Geoserver-devel] maven repo update (I am stuck)
quick update before I turn in for the day.
geotools seem on ares and locally.
Ares has gotten stuck on geowebcache:
[ERROR] Failed to execute goal on project gwc-georss: Could not resolve dependencies for project org.geowebcache:gwc-georss:jar:1.9-SNAPSHOT: Failed to collect dependencies for [org.geowebcache:gwc-core:jar:1.9-SNAPSHOT (compile), com.vividsolutions:jts:jar:1.13 (compile), org.geotools:gt-coverage:jar:15-SNAPSHOT (compile), stax:stax-api:jar:1.0.1 (compile), stax:stax:jar:1.2.0 (compile), junit:junit:jar:4.11 (test), org.geowebcache:gwc-core:jar:tests:1.9-SNAPSHOT (test)]: Failed to read artifact descriptor for org.geotools:gt-coverage:jar:15-SNAPSHOT: Could not transfer artifact
More seriously building geoserver locally now fails:
[ERROR] Failed to execute goal on project gs-monitor-core: Could not resolve dependencies for project org.geoserver.extension:gs-monitor-core:jar:2.9-SNAPSHOT: Could not find artifact com.maxmind:geoip:jar:1.2.3 in boundlessgeo (https://boundless.artifactoryonline.com/boundless/main) → [Help 1]
I had understood that the contents of the previous repo had been collected, based on the above message I appear to be stuck for the evening and will need to regroup for tomorrow.
Jody Garnett
On Fri, Oct 9, 2015 at 8:05 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
*[ERROR] Failed to execute goal on project gwc-georss: Could not resolve
transfer artifact *
Hum... it's here:
https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-coverage/15-SNAPSHOT/
*[ERROR] Failed to execute goal on project gs-monitor-core: Could not
<https://boundless.artifactoryonline.com/boundless/main&gt;\) -> [Help 1]*
This jar is not in the repository indeed. And it's not in central either,
there is a similar jar here:
http://mvnrepository.com/artifact/com.maxmind.geoip/geoip-api/1.2.10
But it seems that is deprecated and a geoip2 is its replacement:
http://mvnrepository.com/artifact/com.maxmind.geoip2/geoip2
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I am now unstuck (cache of previous repository restored).
Additional comments in line.
On 9 October 2015 at 00:46, Andrea Aime <andrea.aime@anonymised.com> wrote:
Not sure - it may of just been a build order issue. After geotools builds on ares I think both geowebcache and geoserver are scheduled concurrently.
I am finding quite a few dependencies that could be updated (such as jpython), however that won’t help our stable and maintenance branches. One thing I am noticing is that projects have gotten better at locating themselves in maven, and we had “personally” loaded some of these dependencies in our repository before (for things like python 2.5.0).
Jody
Hum… it’s here: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-coverage/15-SNAPSHOT/
This jar is not in the repository indeed. And it’s not in central either, there is a similar jar here:
On Fri, Oct 9, 2015 at 3:42 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
jpython), however that won't help our stable and maintenance branches. One
themselves in maven, and we had "personally" loaded some of these
Yes, that'a a sore point, we have a lot of outdated dependencies.
Trouble is finding some that would sponsor the upgrades to more recent
versions...
Maybe after the Wicket upgrade sprint we could do another one for other
upgrades (H2 comes to mind, be we really have a ton)
Ing. Andrea Aime
@geowolf
Technical Lead
Hopefully this change will provide enthusiasm for the activity :slight_smile:
On 9 October 2015 at 06:46, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
Yes, that’a a sore point, we have a lot of outdated dependencies.
Trouble is finding some that would sponsor the upgrades to more recent versions…
Maybe after the Wicket upgrade sprint we could do another one for other upgrades (H2 comes to mind, be we really have a ton)
Ing. Andrea Aime
@geowolf
Technical Lead
