Okay if it is still in the build files then I will continue to maintain it where I see it.
I made the mistake of trying to understand some geoserver data model stuff and am confused about.
Handling of ContactInfo.getAddress() and ContactInfo.getAddressDeliveryPoint():
Handling of online resource:
- settings online resource documented as a fallback URL for organization name
- settings online resource actually used as a default for WFS online source in GetCapabilities generation (which some code assumes is service location)
- Without a settings online ressource WFS GetCapabilities generates a different kind of online resource that references the web service end-point (not the organization name)
SettingsInfo.getOnlineResource()
no user interface but expected by welcome page, only modified by REST API, or on initial creation
javadoc: Provider web site used for default contact information, or service provider information if user has not filled in contact details.
aside: Workspace ServiceInfo user interface also does not allow this to be modified, only modified by REST API, or on initial creation
action: Add this to global settings page page so user can configure it
ContactInfo.getOnlineResource()
- this should be used by the welcome page and is clearly the URL of the website for the organization providing the service
- action: add to contact info page so user can supply a value
WFSInfo.getOnlineResource()
- WFS 1.0.0 specification defines:
The element defines the top-level HTTP URL of this service. Typically the URL of a “home page” for the service.
example is:
http://www.someserver.com/wfs/cwwfs.cgi?
WFS 1.1.0 ServiceIdentification does not have this concept
WFS 2.0.0 does not have this concept, delegates to https://schemas.opengis.net/ows/1.1.0/owsServiceIdentification.xsd
While WFS 1.0.0 spec a plain URL for organiation name, the ESRI WFS examples tend to list the service endpoint (maybe they default to an html page)
GeoServer WFS 1.0.0 implementation returns ${base_url}/geoserver/wfs if SettingsInfo.getOnlineResource() is not available, it should return an html page as with the other services.
action: Change WFS 1.0.0 to default to ${base_url}/geoserver rather than ${base_url}/geoserver/wfs (if settings and wfsinfo online resources are empty)
https://osgeo-org.atlassian.net/browse/GEOS-10668
WMSInfo.getOnlineResource()
ServiceProvider/ProviderStite - should be from SerivceInfo.getOnlineResource()
WMS 1.3 documents online resource as the website of the service provider
WMS GetCapabilites example is inconclusive could be either organization url or service end-point URL.
GeoServer WMS 1.3.0 uses ${base_url}/geoserver to direct user to an html page (if settings online resource not available)
GeoServer WMS 1.1.1 uses ${base_url}/geoserver to direct user to an html page (if settings online resource not available)
action: Check WMSInfo.getOnlineResource() and Settings.getOnlineResource() before defaulting to ${base_url}/geoserver
WMTSInfo.getOnlineResource()
- uses ows as above, does not have the concept of service identification online resource
- it does have ServiceProvider/ProviderSite which performs the same role
- however GWC was not getting the “providerSite” information correctly https://osgeo-org.atlassian.net/browse/GEOS-10664
- action: Determine ProviderSite from WMTSInfo.getOnlineResource() with SettingsInfo.getOnlineResource() as fallback
WCSInfo.getOnlineResource()
WPSInfo.getOnlineResource()
Jody
On Wed, Sep 21, 2022 at 3:56 AM Andrea Aime <andrea.aime@…6887…> wrote:
Hi Jody,
if it’s what I think, it’s still in the build files:
https://github.com/geoserver/geoserver/blob/main/src/pom.xml#L2136
Haven’t used it ages, don’t know if it’s still working. No objections to removing it.
On Wed, Sep 21, 2022 at 2:52 AM Jody Garnett <jody.garnett@anonymised.com.403…> wrote:
I have wandered into a dark corner of geoserver (contact information) and found that we do not have a user interface to define the onlineResource used by the welcome page.
Many of the ContactInformation javadocs have @anonymised.com annotations (which stackexchanges claims is from an old uml plugin. May these be safely removed - or are they still used by an xml or json mapper?
Jody Garnett
Geoserver-devel mailing list
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
