I am running GeoServer 1.5.3 on a Windows box and running Java SDK 1.6.0_03.
When I try and load images greater then 500 mb I get the following error:
4846891 [WARNING]
org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer
- Java heap space
java.lang.OutOfMemoryError: Java heap space
I am referencing a .PNG image with associated world file. The same image
works fine on my laptop which obviously has a fraction of the resources as
the server I am working with. I have read a couple of threads which
reference problems with JAI and memory. Do I need to set the memory
parameters? If so where do I set the memory parameters? The server I am
using has plent of RAM. Any suggestions would be greatly appreciated.
Thanks.
1.6.0_03. When I try and load images greater then 500 mb I get the
following error:
4846891 [WARNING]
- Java heap space
Thanks.
