[Geoserver-devel] memory leak in 2.0.2 and 2.0.x nightly build
This is my first post. Don't know if this should have been posted in the
user forum.
We are struggling with a major memory leak.
Our platform:
o Geoserver 2.0.2, 821 layers, 151 workspaces/datastores
o Win2003 32-bit 4 GB, Java 1.6.0_21, Tomcat 6.0.26, JVM minmx=memmx=1420 MB
We are only using WMS and WFS.
The JVM runs out of heap space very fast, forcing us to reboot Tomcat
every 2 hours.
VisualVM reports that the top consumers (933 MB in total) are:
  java.lang.String: 251 MB
  char: 235 MB
  org.apache.xerces.dom.AttrNSImpl: 217 MB
  java.util.HashMap$Entry 92 MB
  org.apache.xerces.dom.TextImpl: 70 MB
  org.eclipse.xsd.impl.XSDElementDeclarationImpl: 68 MB
The AttrNSImpl looks suspicious. Geoserver 2.0.2 uses Xerces 2.6.2. The
current version is Xerces 2.10.0 (released June 19 2010). Presumably,
it contains a fix for an AttrNSImpl related leak (see
http://web.archiveorange.com/archive/v/4o5nETE1HwzVF6W9n09z), amongst
many other fixes (including memory leaks). However, the above numbers
were generated with geoserver 2.0.2 using xerces 2.10.0 (we bluntly
replaced the Xerces jar).
Is anyone familiar with this behavior? Is Xerces the culprit or are other
objects unintentionally holding references to Xerces objects?
Is this related to http://jira.codehaus.org/browse/GEOS-3534 ??
We also tried the nightly 2.0.x build from July 12 2010. Unfortunately,
the heapspace gets exhausted in a similar way.
Any help appreciated.
Greetings,
Egon
Hi Egon,
This is a known issue that is ongoing right now. It is definitely related to GEOS-3534.
What would help is to know about the request pattern you are executing that shows the leak. The leak is known to occur during DescribeFeatureType and Transaction requests. Any info about how your data is set up and what sort of requests you are making will help.
Thanks.
-Justin
On 10-07-15 10:25 AM, egona wrote:
user forum.
Our platform:
every 2 hours.
   char: 235 MB
Greetings,
Egon
This SF.net email is sponsored by Sprint
What will you do first with EVO, the first 4G phone?
Visit sprint.com/first -- http://p.sf.net/sfu/sprint-com-first
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
About the request pattern. We don't perform Transaction requests (WFS-insert,
WFS-update and WFS-delete). It's primarily
o WMS1.1.1 GetMap requests
  PNG output, ranging from 100x100 to 7500x7500 images
o WFS-1.0 GetFeature requests (including spatial intersect)
  These are as simple-minded as:
   <Query typeName='XXX' srsName='epsg:28992'>
      <ogc:Filter>
        <ogc:And>
          <ogc:Intersects><ogc:PropertyName>XXX</ogc:PropertyName>
             <gml:Polygon srsName='epsg:28992'>XXX</gml:Polygon>
          </ogc:Intersects>
<ogc:PropertyIsEqualTo><ogc:PropertyName>XXX</ogc:PropertyName><ogc:Literal>j</ogc:Literal></ogc
:PropertyIsEqualTo>
        </ogc:And>
     </ogc:Filter>
   </Query></GetFeature>
Out data setup:
o Data (incl spatial) is 30 GB and stored in PostgreSQL-PostGIS 8.3.8
o Data is divided over a large number of database schema's
o Geoserver 2.0.2 is the only application that runs on tomcat 6.0.26
o Geoserver connects through JNDI to the DB using postgresql-8.4-701.jdbc3.jar
o Each database schema has its own geoserver workspace/datastore
o There are 821 layers/featuretypes
o There are 32 SLDs (one FeatureTypeStyle per SLD)
o Native JAI: no (caused errors)
As an aside, the following error frequently appears:
2010-07-15 21:12:22,052 ERROR [org.geotools.jdbc] - There's code using JDBC based datastore and
not disposing them. This may lead to temporary loss of database connections. Please make sure
all data access code calls DataStore.dispose() before freeing all references to it
We have no clue what causes this and if it is part of the problem.
Greetings,
Egon
-----Original Message-----
To: geoserver-devel@lists.sourceforge.net
Date: Thu, 15 Jul 2010 10:32:41 -0600
Subject: Re: [Geoserver-devel] memory leak in 2.0.2 and 2.0.x nightly build
Hi Egon,
Thanks.
-Justin
> Hi,
the
> user forum.
> Our platform:
minmx=memmx=1420 MB
> every 2 hours.
> char: 235 MB
The
other
Unfortunately,
> Greetings,
> Egon
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Justin Deoliveira
Hi Justin,
Today we ran a test using two setups:
Setup 1: 100 workspaces, 100 datastores, 562 layers
Setup 2: 191 workspaces, 191 datastores, 1114 layers
In both cases, the same batch of WMS and WFS requests were sent to geoserver.
At the end of the test, the heap of setup 1 was at 82 MB, whereas the
heap of setup 2 was at 1440 MB. Another difference is that the geoserver
log of setup 2 contains a lot of the following messages:
2010-07-16 19:29:51,927 ERROR [geotools.jdbc] - There's code using JDBC based datastore and not
disposing them. This may lead to temporary loss of database connections. Please make sure all
Have you got any clue if this is caused by bad spatial data, a configuration
error of one of the layers, or perhaps a limit by geoserver?
Greetings,
Egon
Hi Egon,
Thanks.
-Justin
> Hi,
the
> user forum.
> Our platform:
minmx=memmx=1420 MB
> every 2 hours.
> char: 235 MB
The
other
Unfortunately,
> Greetings,
> Egon
Justin Deoliveira
Ok, that number of feature types will bring about yet another problem that will cause a memory leak, not related to the DFT one.
The only way to get around it is to make sure the "feature type cache size" (on the global settings page) setting is greater than the number of feature types in the catalog.
Try increasing them to 563 and 1115 respectively and let me know if that helps.
On 10-07-16 4:57 PM, egona wrote:
Hi Justin,
Greetings,
Egon
Hi Egon,
Thanks.
-Justin
the
user forum.
Our platform:
minmx=memmx=1420 MB
every 2 hours.
    char: 235 MB
The
other
Unfortunately,
Greetings,
Egon
Justin Deoliveira
Justin Deoliveira
hi Justin,
we already did that before executing the tests. We set the feature
type cache size to 4000.
Too big maybe?
ciao, Robert (colleague of Egon)
2010/7/17 Justin Deoliveira <jdeolive@anonymised.com>:
helps.
Hi Justin,
Greetings,
Egon
Hi Egon,
Thanks.
-Justin
the
user forum.
Our platform:
minmx=memmx=1420 MB
every 2 hours.
java\.lang\.String: 251 MB
char\[\]: 235 MB
org\.apache\.xerces\.dom\.AttrNSImpl: 217 MB
java\.util\.HashMap$Entry 92 MB
org\.apache\.xerces\.dom\.TextImpl: 70 MB
org\.eclipse\.xsd\.impl\.XSDElementDeclarationImpl: 68 MB
The
other
Unfortunately,
Greetings,
Egon
Justin Deoliveira
Justin Deoliveira
Geodan IT b.v.
Buitenhaven 27-A
5211 TP 's-Hertogenbosch (NL)
Tel: +31 (0)73 - 692 5151
Fax: +31 (0)20 - 5711 333
Postadres / mailing address
President Kennedylaan 1
1079 MB Amsterdam (NL)
Website: www.geodan.nl
Disclaimer: www.geodan.nl/disclaimer
hi Justin,
Too big maybe?
helps.
Hi Justin,
Greetings,
Egon
Hi Egon,
Thanks.
-Justin
the
user forum.
Our platform:
minmx=memmx=1420 MB
every 2 hours.
char\[\]: 235 MB
The
other
Unfortunately,
Greetings,
Egon
Justin Deoliveira
Justin Deoliveira
Geodan IT b.v.
Buitenhaven 27-A
Hi Justin,
A little more info.
Heap after forcing/requesting a GC (via VisualVM) at the end of each test:
Test 1: 100 workspaces, 562 layers: 86 MB
Test 2: 120 workspaces, 756 layers: 250 MB (jdbc errors)
Test 3: 140 workspaces, 867 layers: 687 MB (jdbc errors)
Test 4: 191 workspaces, 1114 layers: 1414 MB (jdbc errors)
Note that the test (WMS/WFS requests) only affects 23 workspaces. These
are always the same workspaces. The only difference between the tests is
the number of workspaces/layers registered in geoserver.
For all tests, the feature type cache size is set to 4000. We will run
some more tests where we adjust/lower that size. Hopefully, you can
find what's going wrong here.
Greetings,
Egon
To: Justin Deoliveira <jdeolive@anonymised.com>
Cc: geoserver-devel@lists.sourceforge.net
Date: Sat, 17 Jul 2010 11:28:38 +0200
hi Justin,
Too big maybe?
number
that
> helps.
>> Hi Justin,
geoserver.
the
geoserver
references to it
configuration
>> Greetings,
>> Egon
>> From: Justin Deoliveira<jdeolive@anonymised.com>
nightly build
>>> Hi Egon,
executing
your
>>> Thanks.
>>> -Justin
>>>> Hi,
in
>>> the
>>>> user forum.
>>>> Our platform:
>>> minmx=memmx=1420 MB
Tomcat
>>>> every 2 hours.
>>>> char: 235 MB
2.6.2.
>>> The
Presumably,
amongst
numbers
bluntly
are
>>> other
>>> Unfortunately,
>>>> Greetings,
>>>> Egon
>>>> _______________________________________________
>>> Justin Deoliveira
> Justin Deoliveira
Geodan IT b.v.
Buitenhaven 27-A
How many datastores are in play? Unfortunately the size of the workspace cache (which is currently unsettable :() leads to issues as well.
Any chance you can generate a heap dump for me to look at? Just test the server to memory exhaustion and then run:
jmap -dump:live,file=<...> <pid>
Or alternatively just set the flag for the server to generate a heap dump on oom. Also if you could limit the size of the heap as to generate a reasonable sized file that would be helpful as well.
Thanks. Hopefully we can nail down this issue for you.
On 10-07-17 4:38 AM, egona wrote:
Hi Justin,
A little more info.
Greetings,
Egon
To: Justin Deoliveira<jdeolive@anonymised.com>
hi Justin,
Too big maybe?
2010/7/17 Justin Deoliveira<jdeolive@anonymised.com>:
number
that
helps.
Hi Justin,
geoserver.
the
geoserver
references to it
configuration
Greetings,
Egon
nightly build
Hi Egon,
executing
your
Thanks.
-Justin
in
the
user forum.
Our platform:
minmx=memmx=1420 MB
Tomcat
every 2 hours.
     char: 235 MB
2.6.2.
The
Presumably,
amongst
numbers
bluntly
are
other
Unfortunately,
Greetings,
Egon
Justin Deoliveira
Justin Deoliveira
Geodan IT b.v.
Buitenhaven 27-A
Justin Deoliveira
Hi Justin,
We conducted 11 runs of the same test. The amount of heap used at the
end of each test, after requesting a GC, is shown below:
1. 100 workspaces/datastores, 562 layers: 86 MB
2. 101 workspaces/datastores, 563 layers: 68 MB
3. 101 workspaces/datastores, 605 layers: 70 MB
4. 101 workspaces/datastores, 567 layers: 69 MB
5. 101 workspaces/datastores, 565 layers: 69 MB
6. 101 workspaces/datastores, 565 layers: 69 MB
7. 105 workspaces/datastores, 617 layers: 103 MB
8. 110 workspaces/datastores, 666 layers: 110 MB
9. 120 workspaces/datastores, 756 layers: 250 MB
10 140 workspaces/datastores, 867 layers: 687 MB
11 191 workspaces/datastores, 1114 layers: 1414 MB
The only difference between the tests is the number of workspaces, datastores
and layers that are registered in geoserver. The test only affects 23
workspaces.
Each workspace has its own datastore. A datastore belongs to one workspace
(a datastore is not shared among multiple workspaces). All datastores are
attached to the same JNDI data source.
We observed the following during these tests:
o The JDBC errors (DataStore.dispose() is not explicitly called) only
  seem to appear when the number of datastores is 100+.
o The following do not seem to play a role in generating the memory leak:
  o quality of the spatial data
  o size of the map images
  o feature type cache size (when set larger than the number of features)
o Clicking on the following in the geoserver admin does not reduce the
  leaked memory:
    Free locks
    Free memory
    Free JAI memory
    Clear resource cache
    Reload configuration and catalog
So, we think it is linked to number of workspaces, datastores, or layers.
It is maybe interesting to note that no memory leaks were found when
the 191 workspaces were spread accross two geoservers (running in the
same tomcat): one with 100 workspaces and one with 91 workspaces.
Unfortunately, non-disclosure agreements prohibit us to supply a heap
dump :frowning:
We have now setup a development environment for geoserver 2.0.x to study
and tinker the code. Do you have any tips for us? I am thinking about
adding debug info to the caches in org.geoserver.catalog.ResourcePool.
Greetings,
Egon
To: egona <egon.amade@anonymised.com>
Cc: Robert van Seeters <robgis@anonymised.com>, geoserver-devel@lists.sourceforge.net
Date: Mon, 19 Jul 2010 09:22:03 -0600
workspace
the
generate
> Hi Justin,
> A little more info.
test:
These
is
run
> Greetings,
> Egon
> From: Robert van Seeters<robgis@anonymised.com>
build
>> hi Justin,
>> Too big maybe?
problem
cache
>> number
>> that
>>> helps.
>>>> Hi Justin,
>> geoserver.
>> the
>> geoserver
>> references to it
>> configuration
>>>> Greetings,
>>>> Egon
>> nightly build
>>>>> Hi Egon,
>> executing
>> your
help.
>>>>> Thanks.
>>>>> -Justin
>>>>>> Hi,
posted
>> in
>>>>> the
>>>>>> user forum.
>>>>>> Our platform:
>>>>> minmx=memmx=1420 MB
>> Tomcat
>>>>>> every 2 hours.
>>>>>> char: 235 MB
>> 2.6.2.
>>>>> The
>> Presumably,
>> amongst
>> numbers
>> bluntly
>> are
>>>>> other
>>>>> Unfortunately,
>>>>>> Greetings,
>>>>>> Egon
>>>>> Justin Deoliveira
>>> Justin Deoliveira
>> Geodan IT b.v.
>> Buitenhaven 27-A
Justin Deoliveira
Hi Egon,
So yeah, this makes me think it is indeed an issue with the size of the datastore cache, which is by default 100 entries big.
So what we need to do is make this configurable the same way the feature type cache size is. I have created an issue in the tracker.
http://jira.codehaus.org/browse/GEOS-4068
-Justin
On 10-07-20 7:17 AM, egona wrote:
Hi Justin,
workspaces.
   leaked memory:
     Free locks
     Free memory
     Free JAI memory
dump :frowning:
Greetings,
Egon
To: egona<egon.amade@anonymised.com>
Cc: Robert van Seeters<robgis@anonymised.com>, geoserver-devel@lists.sourceforge.net
workspace
the
generate
Hi Justin,
A little more info.
test:
These
is
run
Greetings,
Egon
build
hi Justin,
Too big maybe?
problem
cache
number
that
helps.
Hi Justin,
geoserver.
the
geoserver
references to it
configuration
Greetings,
Egon
nightly build
Hi Egon,
executing
your
help.
Thanks.
-Justin
posted
in
the
user forum.
Our platform:
minmx=memmx=1420 MB
Tomcat
every 2 hours.
      char: 235 MB
2.6.2.
The
Presumably,
amongst
numbers
bluntly
are
other
Unfortunately,
Greetings,
Egon
Justin Deoliveira
Justin Deoliveira
Geodan IT b.v.
Buitenhaven 27-A
Justin Deoliveira
Justin Deoliveira
Hi Justin,
We have run some tests with different-sized datastore caches. In short,
we can confirm that the size of the cache plays a role: to prevent the
memory leak, it should be equal to or greater than the number of
datastores.
In our test case, with 191 datastores, everything works well when the
cache size is set to: 1200, 800, and 400. The heap at the end of those
tests was 120 MB. When set to 150, however, the heap was stuck at 1000 MB.
We haven't investigated the exact cause, but we suspect that the datastore
(org.geotools.jdbc.JDBCDataStore) that is evicted from the cache doesn't
dispose itself properly.
Greetings, Egon
Date: Tue, 20 Jul 2010 11:15:22 -0600
Hi Egon,
feature
-Justin
> Hi Justin,
datastores
> workspaces.
workspace
are
leak:
features)
the
> leaked memory:
> Free locks
> Free memory
> Free JAI memory
layers.
> dump :frowning:
study
> Greetings,
> Egon
build
>> workspace
>> the
>> generate
>>> Hi Justin,
>>> A little more info.
each
>> test:
>> These
tests
>> is
>> run
>>> Greetings,
>>> Egon
nightly
>> build
>>>> hi Justin,
>>>> Too big maybe?
>> problem
>> cache
>>>> number
if
>>>> that
>>>>> helps.
>>>>>> Hi Justin,
to
>>>> geoserver.
whereas
>>>> the
>>>> geoserver
using
>>>> references to it
>>>> configuration
>>>>>> Greetings,
>>>>>> Egon
>>>> nightly build
>>>>>>> Hi Egon,
definitely
>>>> executing
how
>>>> your
>> help.
>>>>>>> Thanks.
>>>>>>> -Justin
>>>>>>>> Hi,
>> posted
>>>> in
>>>>>>> the
>>>>>>>> user forum.
>>>>>>>> Our platform:
>>>>>>> minmx=memmx=1420 MB
>>>> Tomcat
>>>>>>>> every 2 hours.
>>>>>>>> char: 235 MB
>>>> 2.6.2.
>>>>>>> The
>>>> Presumably,
>>>> amongst
>>>> numbers
>>>> bluntly
or
>>>> are
>>>>>>> other
>>>>>>> Unfortunately,
>>>>>>>> Greetings,
>>>>>>>> Egon
>>>>>>> Justin Deoliveira
>>>>> Justin Deoliveira
>>>> Geodan IT b.v.
>>>> Buitenhaven 27-A
>> Justin Deoliveira
Justin Deoliveira
Ok, it is good to confirm that is the issue.
It actually is not the datastores not disposing properly that is the problem. It is that every time a feature type or a datastore is diposed, an event latches on to it that rebuilds the internal object we use to model the wfs schema. When that happens memory leaks.
The fix to prevent leaking in this way is unfortunately not trivial. I hope to implement it soon but it may be something that will have to wait for 2.1.
-Justin
On 10-07-21 4:49 PM, egona wrote:
Hi Justin,
datastores.
Greetings, Egon
Hi Egon,
feature
-Justin
Hi Justin,
datastores
workspaces.
workspace
are
leak:
features)
the
    leaked memory:
      Free locks
      Free memory
      Free JAI memory
layers.
dump :frowning:
study
Greetings,
Egon
build
workspace
the
generate
Hi Justin,
A little more info.
each
test:
These
tests
is
run
Greetings,
Egon
nightly
build
hi Justin,
Too big maybe?
problem
cache
number
if
that
helps.
Hi Justin,
to
geoserver.
whereas
the
geoserver
using
references to it
configuration
Greetings,
Egon
nightly build
Hi Egon,
definitely
executing
how
your
help.
Thanks.
-Justin
posted
in
the
user forum.
Our platform:
minmx=memmx=1420 MB
Tomcat
every 2 hours.
       char: 235 MB
2.6.2.
The
Presumably,
amongst
numbers
bluntly
or
are
other
Unfortunately,
Greetings,
Egon
Justin Deoliveira
Justin Deoliveira
Geodan IT b.v.
Buitenhaven 27-A
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
Hi Justin,
Ok. For us, our patch is sufficient to get things going without having
to periodically restart tomcat. We'll use that version until the
official fix makes it into 2.1 or such.
If someone is interested, we just copied
  main.java.org.vfny.geoserver.global.GeoserverDataDirectory.findGeoServerDataDir()
to
and then changed it a bit so the size of the datastore cache can be set
via a system or Java environment variable named "DATASTORE_CACHE_SIZE".
The code we've added to ResourcePool.java is shown below. Nothing fancy.
     static int DATASTORE_CACHE_SIZE_DEFAULT = 500;
     public ResourcePool(Catalog catalog) {
         dataStoreCache = new DataStoreCache(getDataStoreCacheSize());
     public static int getDataStoreCacheSize() {
        return getEnvVariable("DATASTORE_CACHE_SIZE"
                            , DATASTORE_CACHE_SIZE_DEFAULT);
     public static int getEnvVariable(String varName, int defaultSize) {
         final String typeStrs = { "Java environment variable "
                                   , "Servlet context parameter "
                                   , "System environment variable " };
         int intVal = -1;
         // Loop over variable access methods
         for (int j = 0; j < typeStrs.length; j++) {
             String value = null;
             String typeStr = typeStrs[j];
             // Lookup section
             switch (j) {
             case 0:
                 value = System.getProperty(varName);
                 break;
// case 1:
// value = servContext.getInitParameter(varName);
// break;
             case 2:
                 value = System.getenv(varName);
                 break;
             if (value == null || value.equalsIgnoreCase("")) {
                 LOGGER.finer("Found " + typeStr + varName + " to be unset");
                 continue;
             // Verify section
             try {
                 intVal = Integer.parseInt(value);
             catch(Exception e) {
                 LOGGER.fine("Invalid value for setting " + varName + ": "
                             + value + " is not an integer");
                 continue;
         if (intVal < 0) {
             intVal = defaultSize;
         return intVal;
     class DataStoreCache extends LRUMap {
         public DataStoreCache() {
             this(DATASTORE_CACHE_SIZE_DEFAULT);
         public DataStoreCache(int maxSize) {
             super(maxSize);
Greetings, Egon
Date: Wed, 21 Jul 2010 17:12:39 -0600
diposed,
wait
for 2.1.
-Justin
> Hi Justin,
short,
the
> datastores.
those
1000 MB.
datastore
doesn't
> Greetings, Egon
build
>> Hi Egon,
the
>> feature
>> -Justin
>>> Hi Justin,
the
>> datastores
23
>>> workspaces.
>> workspace
datastores
>> are
only
>> leak:
>> features)
>> the
>>> leaked memory:
>>> Free locks
>>> Free memory
>>> Free JAI memory
>> layers.
when
the
heap
>>> dump :frowning:
>> study
about
>>> Greetings,
>>> Egon
nightly
>> build
>>>> workspace
test
>>>> the
heap
>>>> generate
>>>>> Hi Justin,
>>>>> A little more info.
>> each
>>>> test:
>>>> These
>> tests
>>>> is
will
>>>> run
can
>>>>> Greetings,
>>>>> Egon
>> nightly
>>>> build
>>>>>> hi Justin,
feature
>>>>>> Too big maybe?
>>>> problem
>>>> cache
>>>>>> number
know
>> if
>>>>>> that
>>>>>>> helps.
>>>>>>>> Hi Justin,
sent
>> to
>>>>>> geoserver.
>> whereas
>>>>>> the
>>>>>> geoserver
>> using
>>>>>> references to it
>>>>>> configuration
>>>>>>>> Greetings,
>>>>>>>> Egon
>>>>>> nightly build
>>>>>>>>> Hi Egon,
>> definitely
>>>>>> executing
>> how
>>>>>> your
>>>> help.
>>>>>>>>> Thanks.
>>>>>>>>> -Justin
>>>>>>>>>> Hi,
>>>> posted
>>>>>> in
>>>>>>>>> the
>>>>>>>>>> user forum.
>>>>>>>>>> Our platform:
>>>>>>>>> minmx=memmx=1420 MB
reboot
>>>>>> Tomcat
>>>>>>>>>> every 2 hours.
are:
>>>>>>>>>> char: 235 MB
>>>>>> 2.6.2.
>>>>>>>>> The
>>>>>> Presumably,
>>>>>> amongst
above
>>>>>> numbers
>>>>>> bluntly
>> or
>>>>>> are
>>>>>>>>> other
objects?
>>>>>>>>> Unfortunately,
>>>>>>>>>> Greetings,
>>>>>>>>>> Egon
>>>>>>>>> Justin Deoliveira
>>>>>>> Justin Deoliveira
>>>>>> Geodan IT b.v.
>>>>>> Buitenhaven 27-A
>>>> Justin Deoliveira
>> Justin Deoliveira
Justin Deoliveira
