On Tue, Jan 12, 2016 at 3:59 PM, A Huarte <ahuarte47@anonymised.com> wrote:
Hi all, I get many LOG error messages: "Call MapContent dispose() to
prevent memory leaks"
Yeah, that log statement is unfortunate and annoying, as I believe a memory
leak can only be generated if
there are layer and content listeners around, that GeoServer does not use.
But the check in the finalize method of MapContent is dumb
and it just keeps on complaining for nothing.
I think that they come from GetMap method (
https://github.com/geoserver/geoserver/blob/master/src/wms/src/main/java/org/geoserver/wms/GetMap.java#L116) when
an error occurs. The MapContent object never is disposed, and finally GC
runs its finalize method.
I solve this issue adding the dispose call to the catch clause:
https://github.com/ahuarte47/geoserver/commit/7901f8bd404ae7f664b9a8795d2e7713dc871144
I am right?
Seems like a good point to add it
It makes sense to create a pull request to fix it?
Yes please.
*Geosolutions' Winter Holidays from 24/12 to 6/1*
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
