[Geoserver-devel] Merging the JDK11 branches back to master, GS and GWC
the gwc/gs JDK11 branches are in a good shape for merging, they build and run in our quick tests.
I’d like to merge to master as they are, before the EMF changes, and evaluate the situation
CITE tests wise, and then get the EMF stuff in right after those tests, re-evaluate,
so that we are in a decent shape when the GeoTools package reorg is ready to land.
Any objections? I asked on the chat and got the get go from Jody and Kevin
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
+1
Nuno Oliveira
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
+1, crossing fingers...
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
On Fri, Oct 26, 2018 at 10:26 AM Nuno Oliveira GeoSolutions
<nuno.oliveira@anonymised.com> wrote:
+1
On Fri, Oct 26, 2018 at 8:47 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
I'd like to merge to master as they are, before the EMF changes, and evaluate the situation
Geoserver-devel mailing list
Nuno Oliveira
@nmcoliveira
Software Engineer
