Hi Devs,
I am looking at GEOS-6006 and want to use Springs MVC's interceptors to implement a quick fix (the longer term fix will require some discussion on the this list).
In order the register the interceptor in the WMS module's applicationContext.xml I need to update from the 2.x based DTD to a 3.x XSD version in order to properly register the interceptor. My first cut looks good, I was wondering… Is there any standard guidance related to this conversion in the geoserver codebase? Known issues?
Tom
Hey Tom,
Afaik in the past the pattern has been when a new module is added (mostly extensions and community modules) if the author decides to use the new xsd style they can. And I don’t know of any ill side affects of doing so. But as for porting existing modules to the xsd style not sure that has ever been done.
To clarify though, as I thought the new xsd style was mostly just syntactic sugar around the old stuff, you are saying that the spring feature you are trying to use won’t work at all with the old dtd style? Or is just much easier to work with the new xsd style?
ANyways, regarding any change of this nature (along the same lines as spring upgrades, etc…) we generally try them out on master first in order to give them some more exposure past the continuous testing that is done. And if no issues pop up within a few weeks to a month we allow the change to be backported to the stable branch, given that the change is “stable”, ie has no backward compatibility, stability, or api change concerns.
-Justin
$0.02
On Thu, Sep 12, 2013 at 3:59 PM, Tom Kunicki <tkunicki@anonymised.com01…> wrote:
Hi Devs,
I am looking at GEOS-6006 and want to use Springs MVC’s interceptors to implement a quick fix (the longer term fix will require some discussion on the this list).
In order the register the interceptor in the WMS module’s applicationContext.xml I need to update from the 2.x based DTD to a 3.x XSD version in order to properly register the interceptor. My first cut looks good, I was wondering… Is there any standard guidance related to this conversion in the geoserver codebase? Known issues?
Tom
How ServiceNow helps IT people transform IT departments:
- Consolidate legacy IT systems to a single system of record for IT
- Standardize and globalize service processes across IT
- Implement zero-touch automation to replace manual, redundant tasks
http://pubads.g.doubleclick.net/gampad/clk?id=51271111&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
Thanks, for the response. I wanted to use the “interceptor” element which exists in an alternate namespace. The interceptor registration method available with the DTD style requires nesting under each Mapping instance, with some mapping instances being outside the WMS module (“/**”). With the interceptor element element I can register an interceptor with it’s own mappings.
I’ve issued a pull request against master with the quick fix for GEOS 6006 (https://github.com/geoserver/geoserver/pull/330). The change to the appellationContext.xml file that requires the xdd conversion is here: https://github.com/geoserver/geoserver/pull/330/files#L0R609
Tom
Hi Devs,
Tom
Justin Deoliveira
On Fri, Sep 13, 2013 at 12:58 PM, Justin Deoliveira <jdeolive@anonymised.com>wrote:
Hey Tom,
style they can. And I don't know of any ill side affects of doing so. But
been done.
feature you are trying to use won't work at all with the old dtd style? Or
spring upgrades, etc...) we generally try them out on master first in order
to be backported to the stable branch, given that the change is "stable",
Hum... I'm just wondering, won't a dispatcher callback work at all?
We can also register dynamic servlet filters that extend GeoServerFilter
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea,
I’ll look at the DispatcherCallback and GeoServerFilter. For reference the code is up on as a pull request for inspection…
Tom
Hey Tom,
Hum… I’m just wondering, won’t a dispatcher callback work at all?
Ing. Andrea Aime
@geowolf
Technical Lead
