[Geoserver-devel] milestone release roll call
I am grinding through pull requests trying to sort out what is expected in a milestone release.
If you have any functionality that you want to make the cut please speak up now!
(I am a bit stuck reviewing on Niels REST API work as it looks like discussion is ongoing)
Jody Garnett
Hi Jody,
I think discussions have been resolved. For the time being we do not plan any move away from restful in geoserver and we will keep the user/role stuff as a "bonus" feature of geofence-server for now until it is reimplemented in restful.
Just the spring bean issue (see other email) and it is good to go.
Regards
Niels
Jody Garnett
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
Geoserver-devel mailing list
milestone release artifacts are available for testing:
Jody Garnett
Jody Garnett
The scripts did not manage to produce a DMG (expected) or EXE (unexpected).
While I am used to having to produce a DMG by hand, here are the steps I used to created an EXE.
  1. Windows VM - we use an AccessControl plugin to modify shortcut permission (and it only runs on windows)
  2. Download and install https://sourceforge.net/projects/nsis/?source=typ_redirect
  3. Unzip http://nsis.sourceforge.net/AccessControl_plug-in and copy the dll into the NSIS plugin folder
  4. Create a folder “build” and unzip geoserver-2.8-M0-win.zip
  5. Open up geoserver-2.8-M0-bin.zip and copy the contents out into the build folder (so the LICENSE.txt is next to the GeoServerEXE.nsi file)
  6. Double click on GeoServerEXE.nsi file and watch it compile
I have tried running the installer, and if happily fails to install since this VM does not have Java. If I can ask for a volunteer to test before I proceed with announcement.
The artifacts (including the exe) are now on source forge: https://sourceforge.net/projects/geoserver/files/GeoServer/2.8-M0/
Jody Garnett
Jody Garnett
Jody Garnett
Exe installs and runs Geoserver for me on Windows 7 with Oracle Corporation: 1.8.0_40 (Java HotSpot™ Client VM) 32-bit.
-Jukka Rahkonen-
Jody Garnett
Jody Garnett
Jody Garnett
Thanks Jukka, I will send out the announcement tomorrow then.
On 26 May 2015 at 21:43, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
-Jukka Rahkonen-
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
I booted the M0 war download (basic build) on my local tomcat. Seems fine.
Brad
