[Geoserver-devel] Missing abstract definition of layer group in gwc integration
Behavior in GS-2.4.0:
After some test, i recognise that the abstract definition of a layer group
is not shown in gwc's getCapabilities request of WMS and WMTS as well as in
TMS 1.0.0 document.
I do not know if this behavior is based on specifications. However, the
abstract definition of the ordinary layers are distributiert by the services
of gwc integration over the geoserver.
Even with a getCapabilities demand on the internal WMS service from
Geoserver the abstract definition of a layer group is supplied, only the gwc
Services (WMS, TMS and WMTS) does not support this at the moment.
My question is: Is this a bug or a behavior based on specifications?
Greets,
2StepForward
View this message in context: http://osgeo-org.1560.x6.nabble.com/Missing-abstract-definition-of-layer-group-in-gwc-integration-tp5091032.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Now i have found out the code lines, where the bug should be placed.
In file /gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayer.java/
in function: /public LayerMetaInformation getMetaInformation()/
There will be a subfunction call of /ResourceInfo resourceInfo =
getResourceInfo();/ in line: 308
This subfunction call will get the resourceInfo of a LayerInfo and thus only
regular layers will handle to setup the abstract information.
I have test it with following code change and it should be work:
Now all services of the gwc's geoserver integration will setup the abstract
node for LayerGroups.
I hope it will help to solve this issue.
Lg 2StepForward
View this message in context: http://osgeo-org.1560.x6.nabble.com/Missing-abstract-definition-of-layer-group-in-gwc-integration-tp5091032p5091616.html
On Thu, Nov 28, 2013 at 10:01 AM, 2StepForward <kwegezeder@anonymised.com> wrote:
only
Please check if we already have this in the issue tracker (
http://jira.codehaus.org/browse/GEOS),
if so, add your findings, if not, create a new ticket instead.
Reports just on the mailing list tend to be lost/forgotten about
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hello Andrea.
I've nothing found like this bug in the issue tracker. So it would be good
to record it in the issue tracker.
I could do that, but i haven't a account on http://jira.codehaus.org and it
tell me to contact a JIRA administrators to create an account.
Could you do that?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Missing-abstract-definition-of-layer-group-in-gwc-integration-tp5091032p5091628.html
On Thu, Nov 28, 2013 at 10:42 AM, 2StepForward <kwegezeder@anonymised.com> wrote:
Hello Andrea.
it
Look at http://jira.codehaus.org/browse/GEOS, there are instructions
on how to get an account, and create a ticket, in the top left area
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Bug report under: http://jira.codehaus.org/browse/GEOS-6201
View this message in context: http://osgeo-org.1560.x6.nabble.com/Missing-abstract-definition-of-layer-group-in-gwc-integration-tp5091032p5091652.html
