My logging.properties file includes the UNcommented line:
handlers= java.util.logging.ConsoleHandler
The other handlers are commented out.
the rest of the file, without comments:
.level= INFO
# Not relevant since FileHanders are not included
# but adding them doesn't change things
java.util.logging.FileHandler.pattern = %h/java/%u.log
java.util.logging.FileHandler.limit = 50000
java.util.logging.FileHandler.count = 1
java.util.logging.FileHandler = java.util.logging.SimpleFormatter
java.util.logging.ConsoleHandler.level = INFO
java.util.logging.ConsoleHandler.formatter =
Interestingly, the Resin verbose log says:
Application[http://localhost:8080] starting
Application[http://localhost:8080/geoserver\] closing
Application[http://localhost:8080/geoserver\] starting
FreefsLog: init
java.lang.NullPointerException
Sean
I just tried out that log file with resin 2.1.8 and it worked fine.
The Resin logs make sense, since they are not using the java logger.
Hmmm... I'll take a deeper look next week, testing resin 3.0.3. If
you could also send me your java version and operating system and version
that may prove useful.
thanks,
Chris
.level= INFO
FreefsLog: init
Sean
This SF.net email is sponsored by: SF.net Giveback Program.
Does SourceForge.net help you be more productive? Does it
help you create better code? SHARE THE LOVE, and help us help
YOU! Click Here: http://sourceforge.net/donate/
Geoserver-devel mailing list
