[Geoserver-devel] Missing servlet API in geoserver-2.9-SNAPSHOT-bin.zip?
Startup failure in geoserver-2.9-SNAPSHOT-bin.zip with:
java.lang.NoClassDefFoundError: javax/servlet/http/HttpServletResponse
$ JAVA_HOME=/usr/lib/jvm/java-8-openjdk-amd64 bin/startup.sh
GEOSERVER_HOME environment variable not found, using current
directory. If not set then running this script from other
directories will not work in the future.
GEOSERVER DATA DIR is /home/ben/tmp/geoserver/geoserver-2.9-SNAPSHOT/data_dir
WARNING: Module not found [ssl]
2016-03-24 12:22:03.943:INFO::main: Logging initialized @251ms
java.lang.reflect.InvocationTargetException
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:498)
  at org.eclipse.jetty.start.Main.invokeMain(Main.java:321)
  at org.eclipse.jetty.start.Main.start(Main.java:817)
  at org.eclipse.jetty.start.Main.main(Main.java:112)
Caused by: java.lang.NoClassDefFoundError: javax/servlet/http/HttpServletResponse
  at java.lang.Class.getDeclaredConstructors0(Native Method)
  at java.lang.Class.privateGetDeclaredConstructors(Class.java:2671)
  at java.lang.Class.getConstructors(Class.java:1651)
  at org.eclipse.jetty.util.TypeUtil.construct(TypeUtil.java:542)
  at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.configure(XmlConfiguration.java:345)
  at org.eclipse.jetty.xml.XmlConfiguration.configure(XmlConfiguration.java:262)
  at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1243)
  at java.security.AccessController.doPrivileged(Native Method)
  at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1174)
  ... 7 more
Caused by: java.lang.ClassNotFoundException: javax.servlet.http.HttpServletResponse
  at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
  ... 16 more
Usage: java -jar start.jar [options] [properties] [configs]
        java -jar start.jar --help # for more information
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
It looks like a few spots in the code base did not get the Servlet API 3.0.1 upgrade: servlet-api -> javax.servlet-api
This change also broke some assembly descriptor patterns.
This will also cause all the CITE test to fail as Jetty will not start.
I am testing fixes.
  at
  at
  at
  at
  ... 7 more
  ... 16 more
Director
New Zealand
Not quite right: what appears to have happened is that, in upgrading our dependencies to javax.servlet-api-3.0.1.jar, we have downgraded jetty to javax.servlet-api-3.1.0.jar. Jetty no like.
This is why the web-app module has a test dependency on 3.1.0. See Justin's comment:
https://github.com/geoserver/geoserver/commit/d5086daf3e3fa112ce7ca01889b4957636e6ad9c
Kind regards,
Ben.
Director
New Zealand
Can we update to a newer version of Jetty now?
Justin’s comment:
Kind regards,
Ben.
3.0.1 upgrade: servlet-api → javax.servlet-api
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785351&iu=/4140
Geoserver-devel mailing list
Jody Garnett
This seems to fix the problem locally:
Include Jetty-compatible javax.servlet-api jar in geoserver-*-bin.zip
https://github.com/geoserver/geoserver/commit/c73f26854f27b4018a0ed6ef16830f7df8faed68
I will kick the builds.
Justin's comment:
Kind regards,
Ben.
Director
New Zealand
It looks like you have fixed everything Ben - thanks!
Justin’s comment:
Kind regards,
Ben.
Director
New Zealand
Jody Garnett
