[Geoserver-devel] Missing WCS 1.0.0 Custom Dimension
In my current GeoServer project, we have a custom dimension that shows up and can be queried against in WMS 1.1.1 and 1.3.0, as well as WCS 2.0.1. But for some reason, none of the layers even display the dimension when viewed via getCapabilities or describeCoverage using WCS 1.0.0.
Anyone able to think of a reason why the custom dimension would just be missing entirely from WCS 1.0.0 and, if so, how to add it back in?
David Marks
On Thu, Jun 11, 2015 at 8:25 PM, Marks, David <David.Marks@anonymised.com>
If memory serves me well, WCS 1.0 is limited to support ELEVATION, there is
no support for TIME nor for any
custom dimension.
I believe the limit is in the protocol itself, but I may be wrong
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
