[Geoserver-devel] Misterious EMF related exception
on a production system running an old Geoserver I’m seeing the following stack trace:
Caused by: java.lang.NullPointerException
at org.eclipse.emf.ecore.util.EcoreEList.resolveProxy(EcoreEList.java:212)
at org.eclipse.emf.ecore.util.EcoreEList.indexOf(EcoreEList.java:411)
at org.eclipse.emf.common.util.AbstractEList.remove(AbstractEList.java:463)
at org.geotools.xml.Schemas.dispose(Schemas.java:371)
at org.geoserver.wfs.xml.SchemaCleanerCallback.finished(SchemaCleanerCallback.java:48)
at org.geoserver.ows.Dispatcher.fireFinishedCallback(Dispatcher.java:308)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:285)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
No way to reproduce it locally… looking at the code is seems that it could happen if the item to be removed
is not found in the list, then the code checks if the list contains proxies by trying to unwrap them, and either
it turns out the list contains a null value, or the value is not null, it’s a proxy, and the list has no owner…
The above means nothing to me however… does that ring a bell to anyone? Anything you might have
already seen? It’s happening while making WFS 2.0 requests to a 2.4.x GeoServer, does not happen
with 1.1 and 1.0.
Checked the ticket tracker, could not find anything related…
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Andrea,
It rings a bell but I believe my exception was slightly different, relating to the classpath.
Anyway, the solution for me was setting:
System.setProperty(“org.eclipse.emf.ecore.EPackage.Registry.INSTANCE”,
“org.eclipse.emf.ecore.impl.EPackageRegsitryImpl”);
I noted this thread in my comments:
http://www.eclipsezone.com/eclipse/forums/t108113.html
On Thu, May 19, 2016 at 1:09 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
with 1.1 and 1.0.
Ing. Andrea Aime
@geowolf
Technical Lead
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition of MDM
restrictions. Mobile Device Manager Plus allows you to control only the
apps on BYO-devices by containerizing them, leaving personal data untouched!
https://ad.doubleclick.net/ddm/clk/304595813;131938128;j
Geoserver-devel mailing list
Jason Newmoyer
Newmoyer Geospatial Solutions
843.606.0424
jason@anonymised.com
On Thu, May 19, 2016 at 8:40 PM, Jason Newmoyer <
jason@anonymised.com> wrote:
Andrea,
Thanks for the follow up. Do you have by any chance your stack trace handy?
Was that happening with GeoServer?
Ing. Andrea Aime
@geowolf
Technical Lead
