Good evening GeoServer community,
To start out with I would like to thank everyone who has signed up and tested a few pages:
Alexandre Gacon
Peter Smythe
Andrea Aime
GeoSpatial Techno
Marcus Lingenfelder
With their help we about 1/4 of the way through reviewing the pages:
We identified a consistent problem with complicated tabes not rendering (tables with. Nested notes and figures), these are now processed into definition lists.
https://jodygarnett.github.io/geoserver/data/raster/imagemosaic/configuration/#primary-configuration-file -
Definition lists are styled to look like tables (see what I did there!) which works out great for documenting step by step instructions where field entry is needed.
https://jodygarnett.github.io/geoserver/ -
Examples that change based on version and release are correct (big improvement, you can now cut and paste command line examples):
https://jodygarnett.github.io/geoserver/installation/docker/ -
The download, download extension and download community modules external links look good (we can give it the nice appearance like the docker page later):
https://jodygarnett.github.io/geoserver/extensions/geopkg-output/install/
While I think we are through the big problems I still need to ask for your help:
- I would like to ask 10 volunteers
- If everyone can review 30 pages each we will be done
- Lots of pages can be reviewed in under 1-2 mins:
- locate a row that “needs review”
- click on the “origional” link and open in an other tab
- click on the “migrated” link and open in an other tab
- Swap between the pages to check
- If they are the same (no content is lost), update the review column to be done
- If they are different change “needs review” to describing what is different:
- many pages will have “block quotes” when none were intended (this is something we need to fix by hand before conversion)
Popular request BEFORE / AFTER
Reviewers asked to “see the markdown” that was generated.
- Each page has a view source button at the top showing the generated markdown
- Links to both the original rst and generated md are now available in the review spreadsheet
Sign up sheet
I am going to be focused on the 2.25-RC release candidate this week; but I would like to check back next week with a list of things to fix.
The sign up spreadsheet is here: mkdocs review (open spreadsheet and ask for edit access).
Please reply if you have any questions - I appreciate your help.
Thanks to my employer, and GeoCat Live product, for the opportunity to work on this activity.
Jody Garnett
