[Geoserver-devel] Modification on the GeoPackage WPS process
I am working with the WPS GeoPackageProcess in the gs-geopkg community module and I was asking if I can do some modifications/fix to the code:
  • configure the path for the directory of the .geopkg file to create by adding a new optional field in the input GeoPackageProcessRequest object or a new WPS parameter.
  • make configurable the removal of the .geopkg files created. Also for this I would create another optional field in the GeoPackageProcessRequest object or another WPS parameter.
  • call the Geopackage.init() method after creating the GeoPackage object wrapping the input file(line 104). I would add this method because I have found an exception when trying to create the new .geopkg file.
  • define the input GetMap request CRS from the SRS specified by the GeoPackageProcessRequest object, because I have found that the CRS it is not set by default and an exception can be thrown if the BoundingBox CRS is not WGS84.
    If you have any question, I would be pleased to answer.
Nicola Lagomarsini.
Ing. Nicola Lagomarsini
Junior Software Engineer
Via Poggio alle Viti 1187
Hey Nicola,
These all seems like great improvements. +1 !
-Justin
On Fri, Sep 5, 2014 at 8:43 AM, Nicola Lagomarsini <nicola.lagomarsini@anonymised.com> wrote:
Nicola Lagomarsini.
Slashdot TV.
Video for Nerds. Stuff that matters.
http://tv.slashdot.org/
Geoserver-devel mailing list
Justin Deoliveira
VP Engineering | Boundless
jdeolive@anonymised.com
@boundlessgeo
Hi Justin,
when you have time, could you please take a look at the following pull requests.
These are related to GeoPackage. They introduce the support for an external configurable path and the possibility to configure a file as temporary.
This one contains a minor fix for the MBTilesGetMapOutputFormat when trying to reproject the request bbox and modifies the MBTilesFileWrapper in order to accept an external file.
Thanks.
Nicola Lagomarsini.
2014-09-05 16:48 GMT+02:00 Justin Deoliveira <jdeolive@anonymised.com3839…>:
Hey Nicola,
-Justin
Nicola Lagomarsini.
Slashdot TV.
Justin Deoliveira
@boundlessgeo
Looked over the pull request, all look good Nicola. Merge at your discretion.
On Wed, Sep 10, 2014 at 8:39 AM, Nicola Lagomarsini <nicola.lagomarsini@anonymised.com> wrote:
Hi Justin,
Thanks.
Nicola Lagomarsini.
Justin Deoliveira
@boundlessgeo
2014-09-05 16:48 GMT+02:00 Justin Deoliveira <jdeolive@anonymised.com>:
Hey Nicola,
-Justin
Nicola Lagomarsini.
Slashdot TV.
Justin Deoliveira
@boundlessgeo
