[Geoserver-devel] modification proxy cloning problems
A while back we had a thread discussing some issues with mod proxy cloning that appear to only manifest on osx, jdk 1.7. This issue basically makes it impossible to run GeoServer locally.
The problem manifests itself as a ClassNotFoundException resulting from calls to cloneMap and cloneCollection when the deepCopy argument is set to true. From what I can tell the problem is exactly the one described here:
https://jira.codehaus.org/browse/JRUBY-5142
The class loader being used by ObjectOutputStream sometimes ends up being the parent of the main application class loader, meaning it doesn’t have any of the geotools/geoserver/etc… .classes defined in it. So we end up getting a ClassNotFoundException whenever the map or collection contains an object not defined in the jre runtime class library.
So, how about taking the same approach as the JRuby folks and use a custom ObjectOutputStream that ensures we always use the app class loader?
-Justin
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
On Thu, Jul 3, 2014 at 5:33 AM, Justin Deoliveira <jdeolive@anonymised.com
wrote:
the parent of the main application class loader, meaning it doesn't have
any of the geotools/geoserver/etc.. .classes defined in it. So we end up
Yup, good idea
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Cool. Pull request.
https://github.com/geoserver/geoserver/pull/634
On Thu, Jul 3, 2014 at 12:09 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Justin Deoliveira
@j_deolive
On Thu, Jul 3, 2014 at 5:33 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Yup, good idea
Ing. Andrea Aime
@geowolf
Technical Lead
