I was running into an issue with editing features via WFS in Geoserver with a catalog of thousands of layers. It seems as though the schema for every layer in the workspace has to be built and loaded into memory first, which slow things down significantly (at least for the initial edit) if there are many layers. So I tried to make some modifications to the code which would build only the schema of the layer to be edited, assuming a new boolean global setting "dynamicFeatureTypeSchema" is set to true.
The comparison of this code to the master branch is here: https://github.com/cga-harvard/geoserver/compare/gsmaster_fastwfs?expand=1
When "dynamicFeatureTypeSchema" is set to true, there is one unit test that fails, at this line: https://github.com/geoserver/geoserver/blob/master/src/wfs/src/test/java/org/geoserver/wfs/v1_1/GetFeatureTest.java#L467
I'd love to get some input on what you think of this approach and whether there might be a better solution.
-Matt
Hi Matt,
Justin will have to chime in to give you more information on this one, but the
way I understand things, we should be building the large schema once and
caching it, because building it request by request is expensive.
However it seems that in your case the schema is not cached, but rebuilt
for every request… which is new to me
On Mon, Jun 9, 2014 at 3:42 PM, Matt Bertrand <mbertrand@anonymised.com> wrote:
assuming a new boolean global setting “dynamicFeatureTypeSchema” is set
to true.
When “dynamicFeatureTypeSchema” is set to true, there is one unit test
I’d love to get some input on what you think of this approach and
-Matt
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://www.hpccsystems.com
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The schema is being built once and then cached - for awhile. But the cache doesn't seem to last very long, maybe because new layers are being added on a pretty regular basis? I'm using Geoserver in conjunction with GeoNode, so users are constantly uploading new data (there are over 12K layers now). When a user tries to edit/add features to a layer, if the schema needs to be rebuilt again, it usually takes at least a few minutes for that to happen, and the system appears broken because it doesn't respond promptly. So I wrote these modifications to address this problem by loading on request only the schema of the layer being edited.
-Matt
On 06/10/2014 04:37 AM, Andrea Aime wrote:
Hi Matt,
for every request... which is new to me
On Mon, Jun 9, 2014 at 3:42 PM, Matt Bertrand <mbertrand@anonymised.com <mailto:mbertrand@anonymised.com>> wrote:
memory
edited,
is set
to true.
<https://urldefense.proofpoint.com/v1/url?u=https://github.com/cga-harvard/geoserver/compare/gsmaster_fastwfs?expand%3D1&k=AjZjj3dyY74kKL92lieHqQ%3D%3D
&r=E51gnZ%2BcyXbMGQZxn%2FD1gw7E4%2FG%2Bn9A8lGzpPjSUKD4%3D
&m=OT%2B%2Bq4Rw%2F8JRsvmqJLI8PEPRy6YSdfVOboyX7FtnehM%3D
&s=1d763aef28d233deff781edb9f8ef39fd040c2c1997dc9eb0b398e2a0cd5d021>
<https://urldefense.proofpoint.com/v1/url?u=https://github.com/geoserver/geoserver/blob/master/src/wfs/src/test/java/org/geoserver/wfs/v1_1/GetFeatureTest.java%23L467&k=AjZjj3dyY74kKL92lieHqQ%3D%3D
&s=cfca207a44a2a370998bc41c6bb71d5552db0ab552b9879a9a6c8d2f430c0974>
-Matt
Solutions
<https://urldefense.proofpoint.com/v1/url?u=http://www.hpccsystems.com&k=AjZjj3dyY74kKL92lieHqQ%3D%3D
&s=141907d1af2831f55a276e050fa22780550936cefc3dd46c221ffa589d28f922>
<mailto:Geoserver-devel@lists.sourceforge.net>
<https://urldefense.proofpoint.com/v1/url?u=https://lists.sourceforge.net/lists/listinfo/geoserver-devel&k=AjZjj3dyY74kKL92lieHqQ%3D%3D
&s=7ff38f5228bde8f9c19f29b8fb0af417dec3f2dc3ede584fdffc9f9b0fcf4dca>
Ing. Andrea Aime
@geowolf
Technical Lead
http://www.geo-solutions.it <https://urldefense.proofpoint.com/v1/url?u=http://www.geo-solutions.it&k=AjZjj3dyY74kKL92lieHqQ%3D%3D%0A&r=E51gnZ%2BcyXbMGQZxn%2FD1gw7E4%2FG%2Bn9A8lGzpPjSUKD4%3D%0A&m=OT%2B%2Bq4Rw%2F8JRsvmqJLI8PEPRy6YSdfVOboyX7FtnehM%3D%0A&s=3fe30fab2deb30fbb1bc33d10c774812137797ac1741c2a509d1c36aa566fe17>
http://twitter.com/geosolutions_it <https://urldefense.proofpoint.com/v1/url?u=http://twitter.com/geosolutions_it&k=AjZjj3dyY74kKL92lieHqQ%3D%3D
&s=ede60cd86dba681f8320820f45771e27e9222c2a1f3272da5fefb4b10a948126>
On Tue, Jun 10, 2014 at 1:21 PM, Matt Bertrand <mbertrand@anonymised.com>
Right, it's getting dropped every time we add a new vector layer.
Yes, understandable. Wondering how much it will affect the "normal"
GetFeature cycle though
Anyways, waiting for Justin to chime in, he's the expert on this
Ing. Andrea Aime
@geowolf
Technical Lead
