the build on the windows server is currently broken on the monitoring hibernate extension
with the following issue (not sure if permanently, or randomly):
Tests run: 25, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 5.226 sec <<< FAILURE!
org.geoserver.monitor.hib.HibernateMonitorDAO2Test Time elapsed: 2414 sec <<< ERROR!
org.h2.jdbc.JdbcSQLException: Cannot delete file C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\monitor\hibernate\target\monitoring\monitoring.1.log.db [90025-119]
at org.h2.message.Message.getSQLException(Message.java:106)
at org.h2.message.Message.getSQLException(Message.java:117)
at org.h2.message.Message.getSQLException(Message.java:76)
at org.h2.store.fs.FileSystemDisk.delete(FileSystemDisk.java:150)
at org.h2.util.FileUtils.delete(FileUtils.java:296)
at org.h2.tools.DeleteDbFiles.process(DeleteDbFiles.java:108)
at org.h2.tools.DeleteDbFiles.process(DeleteDbFiles.java:95)
at org.h2.tools.DeleteDbFiles.execute(DeleteDbFiles.java:77)
at org.geoserver.monitor.hib.HibernateMonitorDAO2Test.destroy(HibernateMonitorDAO2Test.java:60)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:37)
at org.junit.runners.ParentRunner.run(ParentRunner.java:236)
I’ve been looking at the code, and it seems to me that it’s orderly closing down the database connections,
so not sure why this is happening (the above should happen only if H2 is still keeping a finger on those files, no?)
However, there is a simple workaround: have the test use an in memory H2 database instead
of a file based one.
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
+1
Could this be related to locking files on windows?
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
On Sat, Sep 28, 2013 at 9:47 PM, Andrea Aime
<andrea.aime@anonymised.com> wrote:
hibernate extension
<<< FAILURE!
<<< ERROR!
[90025-119]
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
I've been looking at the code, and it seems to me that it's orderly closing
database instead
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most
from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60133471&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
On Sun, Sep 29, 2013 at 11:23 PM, Simone Giannecchini <
simone.giannecchini@anonymised.com> wrote:
+1
Agreed, yet, that woudl happen only if something keeps the file open... and
I see the code
closing down everything (executors for asynch request logging, connection
pool, and so on)
before trying to delete the file, that's why I'm a bit confused as to why
the file is still locked
anyways. Most likely, I'm missing something that is not being closed as it
should, or some
asynch thread that is still on the loose with a hibernat connection in its
hands...
Ing. Andrea Aime
@geowolf
Technical Lead
if my memory serves me right, if you lock&map a file on windows there
is not way to unmap explicitly.
As such if you try to delete it right away that will fail. This is why
the fileimageinput stream in imageio-ext uses randomaccess file rather
tha filechannels.
Simone Giannecchini
@simogeo
Founder/Director
On Sun, Sep 29, 2013 at 10:29 PM, Andrea Aime
<simone.giannecchini@anonymised.com> wrote:
+1
I see the code
pool, and so on)
should, or some
hands...
Ing. Andrea Aime
@geowolf
Technical Lead
Oh the fun of windows locking issues. +1 on changing the unit tests to use the h2 in memory option.
On Sun, Sep 29, 2013 at 3:31 PM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
tha filechannels.
Simone Giannecchini
@simogeo
Founder/Director
+1
Agreed, yet, that woudl happen only if something keeps the file open… and
I see the code
pool, and so on)
before trying to delete the file, that’s why I’m a bit confused as to why
anyways. Most likely, I’m missing something that is not being closed as it
should, or some
hands…
Ing. Andrea Aime
@geowolf
Technical Lead
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
