[Geoserver-devel] more issues with JAI
Seems like two version of jai_imageio are getting pulled in. From the dependnecy tree:
+- org.geoserver:platform:jar:1.7.2:compile
| +- javax.media:jai_core:jar:1.1.3:compile
| +- javax.media:jai_codec:jar:1.1.3:compile
| \- javax.media:jai_imageio:jar:1.1:compile
+- org.geoserver:wcs:jar:1.7.2:compile
| +- org.geotools:gt-referencing:jar:2.5.3:compile
| | \- commons-pool:commons-pool:jar:1.3:compile
| +- org.geotools:gt-arcgrid:jar:2.5.3:compile
| | \- it.geosolutions.imageio-ext:imageio-ext-arcgrid...
| | +- it.geosolutions.imageio-ext:imageio-ext-customstreams...
| | \- com.sun:jai_imageio:jar:1.0:compile
Removing manually the 1.0 version seems to fix the issue. So I plan to add an exclusion to the wcs pom.xml which excludes the jai_image io dependency from the arcgrid dependency.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
from your log I can’t see the version of imageio-ext-arcgrid. It should be 1.0.0, right?
It depends on the main imageio-ext-1.0.0.pom. I have checked, the imageio-ext-1.0.0.pom contained in the Refractions repository is 3 days old and it depends on jai_imageio-1.1.
I guess your local repo has an early version taken during my 1.0.0 release deployment before your call to fix geotools bugs for the 2.5.3 release until monday.
Can you check it?
Daniele
On Wed, Jan 21, 2009 at 3:03 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
dependnecy tree:
± org.geoserver:platform:jar:1.7.2:compile
| ± javax.media:jai_core:jar:1.1.3:compile
| ± javax.media:jai_codec:jar:1.1.3:compile
± org.geoserver:wcs:jar:1.7.2:compile
| ± org.geotools:gt-referencing:jar:2.5.3:compile
| ± org.geotools:gt-arcgrid:jar:2.5.3:compile
| | - it.geosolutions.imageio-ext:imageio-ext-arcgrid…
| | ± it.geosolutions.imageio-ext:imageio-ext-customstreams…
-Justin
Justin Deoliveira
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
Geoserver-devel mailing list
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
Daniele Romagnoli ha scritto:
Hi Justin,
from your log I can't see the version of imageio-ext-arcgrid. It should be 1.0.0, right?
Can you check it?
Did you push out a 1.0.1 to avoid such issues to happen at all?
(but I guess even if you did, the code on the 2.5.3 tag wouldn't
have been affected unless you asked jdeolive to change the
deps).
Andrea Aime
Hi Andrea,
Yes, I have already deployed the 1.0.1 version which should be dependency for the future release since we have delayed the geotiff bug fix and the gt-imageio-ext-gdal inclusion.
Yesterday, when doing tests with you, I have only re-deployed imageio-ext-tiff-1.0.0 which is no more needed.
Daniele
Hi Justin,
Can you check it?
(but I guess even if you did, the code on the 2.5.3 tag wouldn’t
deps).
Andrea Aime
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Ok, I guess that is the problem. But as Andrea stated... there wold be now way to get the new pom if no version changed and it is not a snapshot right?
At this point I am a little lost about what is going on. At this point I *think* I have a release that works, but things seem to keep popping up.
Andrea/Daniele: Do you mind looking over the following list of libs we are shipping with to see if anything is off. Thanks.
acegi-security-1.0.3.jar
activation-1.1.jar
ant-optional-1.5.1.jar
antlr-2.7.2.jar
aopalliance-1.0.jar
batik-awt-util-1.6.jar
batik-bridge-1.6.jar
batik-css-1.6.jar
batik-dom-1.6.jar
batik-ext-1.6.jar
batik-gvt-1.6.jar
batik-parser-1.6.jar
batik-script-1.6.jar
batik-svg-dom-1.6.jar
batik-svggen-1.6.jar
batik-transcoder-1.6.jar
batik-util-1.6.jar
batik-xml-1.6.jar
cglib-nodep-2.1_3.jar
com.noelios.restlet-1.0.8.jar
com.noelios.restlet.ext.servlet-1.0.8.jar
com.noelios.restlet.ext.simple-1.0.8.jar
common-2.2.1.jar
commons-beanutils-1.7.0.jar
commons-codec-1.3.jar
commons-collections-3.1.jar
commons-dbcp-1.2.2.jar
commons-digester-1.7.jar
commons-fileupload-1.2.1.jar
commons-httpclient-2.0.jar
commons-io-1.3.2.jar
commons-jxpath-1.2.jar
commons-lang-2.1.jar
commons-logging-1.1.1.jar
commons-pool-1.3.jar
commons-validator-1.1.4.jar
data-1.7.2.jar
easymock-2.3.jar
easymockclassextension-2.3.jar
ecore-2.2.2.jar
ezmorph-1.0.3.jar
freemarker-2.3.13.jar
geoapi-2.2-20081020.191707-33.jar
geowebcache-1.0.1.jar
gt-api-2.5.3.jar
gt-arcgrid-2.5.3.jar
gt-coverage-2.5.3.jar
gt-cql-2.5.3.jar
gt-data-2.5.3.jar
gt-epsg-hsql-2.5.3.jar
gt-geotiff-2.5.3.jar
gt-graph-2.5.3.jar
gt-gtopo30-2.5.3.jar
gt-image-2.5.3.jar
gt-imagemosaic-2.5.3.jar
gt-jdbc-2.5.3.jar
gt-main-2.5.3.jar
gt-metadata-2.5.3.jar
gt-postgis-2.5.3.jar
gt-property-2.5.3.jar
gt-referencing-2.5.3.jar
gt-render-2.5.3.jar
gt-shapefile-2.5.3.jar
gt-shapefile-renderer-2.5.3.jar
gt-validation-2.5.3.jar
gt-wfs-2.5.3.jar
gt-wms-2.5.3.jar
gt-xml-2.5.3.jar
gt-xsd-core-2.5.3.jar
gt-xsd-filter-2.5.3.jar
gt-xsd-gml2-2.5.3.jar
gt-xsd-gml3-2.5.3.jar
gt-xsd-ows-2.5.3.jar
gt-xsd-wfs-2.5.3.jar
gwc-1.7.2.jar
h2-1.1.104.jar
hsqldb-1.8.0.7.jar
imageio-ext-arcgrid-1.0.0.jar
imageio-ext-customstreams-1.0.0.jar
itext-2.0.6.jar
jai_codec-1.1.3.jar
jai_core-1.1.3.jar
jai_imageio-1.1.jar
jdom-1.0.jar
jettison-1.0-RC2.jar
json-lib-2.1-jdk13.jar
jsr-275-1.0-beta-2.jar
jstl-1.0.6.jar
jts-1.9.jar
log4j-1.2.14.jar
lucene-1.4.3.jar
mail-1.4.jar
main-1.7.2.jar
net.opengis.ows-2.5.3.jar
net.opengis.wcs-2.5.3.jar
net.opengis.wfs-2.5.3.jar
org.json-2.0.jar
org.restlet-1.0.8.jar
org.restlet.ext.freemarker-1.0.8.jar
org.restlet.ext.json-1.0.1.jar
org.restlet.ext.spring-1.0.8.jar
org.simpleframework-3.1.3.jar
org.w3.xlink-2.5.3.jar
oro-2.0.8.jar
ows-1.7.2-tests.jar
ows-1.7.2.jar
picocontainer-1.2.jar
platform-1.7.2.jar
postgis-driver-1.0.jar
postgresql-8.1-407.jdbc3.jar
spring-aop-2.5.5.jar
spring-beans-2.5.5.jar
spring-context-2.5.5.jar
spring-context-support-2.5.5.jar
spring-core-2.5.5.jar
spring-jdbc-2.5.5.jar
spring-tx-2.5.5.jar
spring-web-2.5.5.jar
spring-webmvc-2.5.5.jar
spring-webmvc-struts-2.5.5.jar
standard-1.0.6.jar
stax-api-1.0.1.jar
struts-1.2.9.jar
validation-1.7.2.jar
vecmath-1.3.1.jar
velocity-1.4.jar
velocity-dep-1.4.jar
wcs-1.7.2.jar
wcs1_1-1.7.2.jar
wfs-1.7.2.jar
wfs11-1.7.2.jar
wms-1.7.2.jar
xalan-2.7.0.jar
xercesImpl-2.4.0.jar
xml-apis-1.0.b2.jar
xml-apis-xerces-2.7.1.jar
xpp3-1.1.3.4.O.jar
xpp3_min-1.1.4c.jar
xsd-2.2.2.jar
xstream-1.3.jar
Daniele Romagnoli wrote:
Hi Justin,
Can you check it?
Daniele
On Wed, Jan 21, 2009 at 3:03 AM, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
    dependnecy tree:
    | +- javax.media:jai_core:jar:1.1.3:compile
    | +- javax.media:jai_codec:jar:1.1.3:compile
    | \- javax.media:jai_imageio:jar:1.1:compile
    | +- org.geotools:gt-referencing:jar:2.5.3:compile
    | | \- commons-pool:commons-pool:jar:1.3:compile
    | +- org.geotools:gt-arcgrid:jar:2.5.3:compile
    | | \- it.geosolutions.imageio-ext:imageio-ext-arcgrid...
    | | +- it.geosolutions.imageio-ext:imageio-ext-customstreams...
    | | \- com.sun:jai_imageio:jar:1.0:compile
    -Justin
    Justin Deoliveira
    <mailto:Geoserver-devel@lists.sourceforge.net>
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Hi Justin,
On Wed, Jan 21, 2009 at 3:34 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Ok, I guess that is the problem. But as Andrea stated… there wold be now way to get the new pom if no version changed and it is not a snapshot right?
As I said to Andrea I have deployed 1.0.0 on refractions before Sunday. Then, I have redeployed only imageio-ext-tiff-1.0.0. I know, it’s not a good practice… my fault.
I have guessed that until a dependency isn’t required by a module, maven wasn’t download it therefore I have redeployed a minimally fixed version.
It could be possible that after setting arcgrid module depending on imageio-ext 1.0.0 (on 19-01), I have accidentally redeployed a 1.0.0 version.
I’m really sorry. My mistake, maybe due to my haste of preparing things for the release. This won’t happen no more.
In case you feel unsafe, you could delete your local imageio-ext repo. Anyway, your release should be ok. Comparing your list with my local geoserver build I haven’t found any difference.
Let me know if you need help.
Daniele
At this point I am a little lost about what is going on. At this point I think I have a release that works, but things seem to keep popping up.
activation-1.1.jar
antlr-2.7.2.jar
aopalliance-1.0.jar
batik-css-1.6.jar
batik-dom-1.6.jar
batik-ext-1.6.jar
batik-gvt-1.6.jar
batik-util-1.6.jar
batik-xml-1.6.jar
common-2.2.1.jar
data-1.7.2.jar
easymock-2.3.jar
ecore-2.2.2.jar
ezmorph-1.0.3.jar
gt-api-2.5.3.jar
gt-cql-2.5.3.jar
gt-data-2.5.3.jar
gt-graph-2.5.3.jar
gt-image-2.5.3.jar
gt-jdbc-2.5.3.jar
gt-main-2.5.3.jar
gt-render-2.5.3.jar
gt-wfs-2.5.3.jar
gt-wms-2.5.3.jar
gt-xml-2.5.3.jar
gwc-1.7.2.jar
h2-1.1.104.jar
hsqldb-1.8.0.7.jar
itext-2.0.6.jar
jai_codec-1.1.3.jar
jai_core-1.1.3.jar
jai_imageio-1.1.jar
jdom-1.0.jar
jstl-1.0.6.jar
jts-1.9.jar
log4j-1.2.14.jar
lucene-1.4.3.jar
mail-1.4.jar
main-1.7.2.jar
org.json-2.0.jar
oro-2.0.8.jar
ows-1.7.2-tests.jar
ows-1.7.2.jar
platform-1.7.2.jar
spring-tx-2.5.5.jar
standard-1.0.6.jar
stax-api-1.0.1.jar
struts-1.2.9.jar
vecmath-1.3.1.jar
velocity-1.4.jar
wcs-1.7.2.jar
wcs1_1-1.7.2.jar
wfs-1.7.2.jar
wfs11-1.7.2.jar
wms-1.7.2.jar
xalan-2.7.0.jar
xml-apis-1.0.b2.jar
xpp3-1.1.3.4.O.jar
xpp3_min-1.1.4c.jar
xsd-2.2.2.jar
xstream-1.3.jar
Hi Justin,
Can you check it?
Daniele
On Wed, Jan 21, 2009 at 3:03 AM, Justin Deoliveira <jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)> wrote:
Seems like two version of jai_imageio are getting pulled in. >From the
dependnecy tree:
-Justin
Justin Deoliveira
mailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.come.net)
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
No problem Daniele, no need to be sorry. The quality of your work far out weighs any hassle that comes up at release time :).
Thanks for looking over the deps. I have not found no additional issues and cite tests are looking good so i am confident to release.
Thanks again.
-Justin
Hi Justin,
On Wed, Jan 21, 2009 at 3:34 PM, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
    snapshot right?
As I said to Andrea I have deployed 1.0.0 on refractions before Sunday. Then, I have redeployed only imageio-ext-tiff-1.0.0. I know, it's not a good practice... my fault.
I have guessed that until a dependency isn't required by a module, maven wasn't download it therefore I have redeployed a minimally fixed version.
I'm really sorry. My mistake, maybe due to my haste of preparing things for the release. This won't happen no more.
In case you feel unsafe, you could delete your local imageio-ext repo. Anyway, your release should be ok. Comparing your list with my local geoserver build I haven't found any difference.
Daniele
    popping up.
    activation-1.1.jar
    antlr-2.7.2.jar
    aopalliance-1.0.jar
    batik-css-1.6.jar
    batik-dom-1.6.jar
    batik-ext-1.6.jar
    batik-gvt-1.6.jar
    batik-util-1.6.jar
    batik-xml-1.6.jar
    common-2.2.1.jar
    data-1.7.2.jar
    easymock-2.3.jar
    ecore-2.2.2.jar
    ezmorph-1.0.3.jar
    gt-api-2.5.3.jar
    gt-cql-2.5.3.jar
    gt-data-2.5.3.jar
    gt-graph-2.5.3.jar
    gt-image-2.5.3.jar
    gt-jdbc-2.5.3.jar
    gt-main-2.5.3.jar
    gt-render-2.5.3.jar
    gt-wfs-2.5.3.jar
    gt-wms-2.5.3.jar
    gt-xml-2.5.3.jar
    gwc-1.7.2.jar
    h2-1.1.104.jar
    hsqldb-1.8.0.7.jar
    itext-2.0.6.jar
    jai_codec-1.1.3.jar
    jai_core-1.1.3.jar
    jai_imageio-1.1.jar
    jdom-1.0.jar
    jstl-1.0.6.jar
    jts-1.9.jar
    log4j-1.2.14.jar
    lucene-1.4.3.jar
    mail-1.4.jar
    main-1.7.2.jar
    org.json-2.0.jar
    oro-2.0.8.jar
    ows-1.7.2-tests.jar
    ows-1.7.2.jar
    platform-1.7.2.jar
    spring-tx-2.5.5.jar
    standard-1.0.6.jar
    stax-api-1.0.1.jar
    struts-1.2.9.jar
    vecmath-1.3.1.jar
    velocity-1.4.jar
    wcs-1.7.2.jar
    wcs1_1-1.7.2.jar
    wfs-1.7.2.jar
    wfs11-1.7.2.jar
    wms-1.7.2.jar
    xalan-2.7.0.jar
    xml-apis-1.0.b2.jar
    xpp3-1.1.3.4.O.jar
    xpp3_min-1.1.4c.jar
    xsd-2.2.2.jar
    xstream-1.3.jar
        Hi Justin,
        Can you check it?
        Daniele
         >From the
           dependnecy tree:
        I plan to
        jai_image io
           -Justin
           Justin Deoliveira
        <mailto:Geoserver-devel@lists.sourceforge.net>>
        Software Engineer
        Via Carignoni 51
        55041 Camaiore (LU)
        fax: +39 0584983027
    -- Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
