I've got Geoserver set running in Tomcat and am sending it requests through Google Earth.
I have 3 layers that I'm querying. 1 default shapefile (states), and 2 sde layers. I am using Gabriel's ArcSDE jar (his Geotools fixes/changes don't seem to have made it to the latest RC2).
The shapefile acts funny on GE, but this may be a GE issue (although it was fine with 1.6.4). I'm going to test this a bit more, maybe using some else's GE.
The SDE layers seem to work 2/3 of the time. I have a stack trace of the exception but have no idea where the problem lies...It's a simple use case, both layers turned on in GE (nothing else turned on), and I pan somewhere to force 2 requests to be sent. The layer with less data seems to mostly work, the other time has a 50% success rate.
Here's the exception:
2008-09-03 09:28:02,812 ERROR [geoserver.ows] -
java.io.IOException
at org.vfny.geoserver.wms.responses.map.kml.KMZMapProducer.writeTo(KMZMapProducer.java:153)
at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:560)
at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:648)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:198)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Unknown Source)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
at org.vfny.geoserver.wms.responses.map.kml.KMZMapProducer.writeTo(KMZMapProducer.java:150)
... 52 more
Caused by: java.lang.IllegalStateException: Cannot create a session after the response has been committed
at org.apache.catalina.connector.Request.doGetSession(Request.java:2301)
at org.apache.catalina.connector.Request.getSession(Request.java:2075)
at org.apache.catalina.connector.RequestFacade.getSession(RequestFacade.java:833)
at org.apache.catalina.connector.RequestFacade.getSession(RequestFacade.java:844)
at org.vfny.geoserver.util.Requests.getBaseUrl(Requests.java:92)
at org.geoserver.wms.util.WMSRequests.getBaseUrl(WMSRequests.java:48)
at org.geoserver.wms.util.WMSRequests.getBaseUrl(WMSRequests.java:63)
at org.geoserver.wms.util.WMSRequests.getGetLegendGraphicUrl(WMSRequests.java:203)
at org.vfny.geoserver.wms.responses.map.kml.KMLUtils.getLegendGraphicUrl(KMLUtils.java:146)
at org.vfny.geoserver.wms.responses.map.kml.KMLLegendTransformer$KMLLegendTranslator.encode(KMLLegendTransformer.java:63)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeLegend(KMLTransformer.java:260)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:155)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
... 54 more
Refractions Research
Suite 300 - 1207 Douglas St
Victoria, BC, V8W 2E7, Canada
ph: (250) 383-3022
fax:(250) 383-2140
