[Geoserver-devel] Mosaic Native Acceleration GUI option bugged?
Looking at the docs and the GUI for the Mosaic Native Acceleration option under Image Processing, is it possible this UI element is bugged right now? I’m not sure how to hit the criteria to enable it, or what the intent is for when it’s supposed to be enabled/disabled.
For reference, the code for the page is here:
Ugh, sent to early:
The page is here:
https://github.com/geoserver/geoserver/blob/master/src/web/core/src/main/java/org/geoserver/web/admin/JAIPage.java#L77
The checkbox seems to be enabled only if JAIExt is enabled and the JAIExt operations does not contain mosaic. However, this condition seems impossible to fulfill in my testing? The JAI EXT ops always contains Mosaic if JAI-EXT is enabled, even with Mosaic set to plain JAI.
Also, wouldn’t it make sense to be able to enable this if JAI-EXT is disabled altogether? Previously this checkbox had no conditional attached.
Devon
On Fri, Nov 3, 2017 at 11:57 AM, Devon Tucker <dtucker@anonymised.com> wrote:
On Fri, Nov 3, 2017 at 8:00 PM, Devon Tucker <dtucker@anonymised.com>
wrote:
Also, wouldn't it make sense to be able to enable this if JAI-EXT is
Agreed, looked at the code... seems like a NPE prevention gone wrong.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
