[Geoserver-devel] Mosaicing Georaster
I am planning to write code for mosaicing oracle spatial Georaster data. I
know how to retrieve and manipulate single georaster. But I am not getting
any idea on how to handle mosaic georaster. Please share any idea on
following.
1. How to calculate envelop for mosaci georaster data from database?
2. Steps to retrive and merge georaster data based on the envelope provided.
Please share atleast any over all idea on how to do this.
cheers,
baskar
View this message in context: http://old.nabble.com/Mosaicing-Georaster-tp27714355p27714355.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Baski@anonymised.com wrote:
following.
You should subscribe to mailing list before sending mails.
Anyways, there has been some work on this area already, see:
http://jira.codehaus.org/browse/GEOT-2905
We're looking into integrating it, but it's not easy since
none of the developers have a use for GeoRaster as of today,
so it's difficult to find the time to test the code, avoid
any direct dependency to the Oracle specific API so that it
builds even without the Oracle jars (since there
are redistribution issues with the license of those jars)
and so on.
But it may work well for you as it is
Thanks for your reply andrea.
I had gone through the code but still I couldn't understand how to find
calculate bounding box which covers all mosaic images. Also please tell
me how to merge the images in terms of envelope calculation for
resulting image.
Please give any idea for my problem.
-----Original Message-----
Sent: Sunday, February 28, 2010 3:35 AM
To: Baskar, Dhanapal
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Mosaicing Georaster
data. I
getting
following.
provided.
and so on.
This message may contain confidential or proprietary information intended only for the use of the
addressee(s) named above or may contain information that is legally privileged. If you are
not the intended addressee, or the person responsible for delivering it to the intended addressee,
you are hereby notified that reading, disseminating, distributing or copying this message is strictly
prohibited. If you have received this message by mistake, please immediately notify us by
replying to the message and delete the original message and any copies immediately thereafter.
Thank you.
FACLD
