+0
-Jukka Rahkonen-
Lähettäjä: Ian Turton <ijturton@…403…>
Lähetetty: perjantai 25. lokakuuta 2019 11.28
Vastaanottaja: Daniele Romagnoli <daniele.romagnoli@…1268…>
Kopio: Geoserver-devel geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] Motion: moving GeoServer TimeParser (gs-ows) code to GeoTools
+1 from me
Ian
On Fri, 25 Oct 2019 at 09:22, Daniele Romagnoli <daniele.romagnoli@…1268…> wrote:
I would like to move the GeoServer TimeParser code contained in gs-ows module, down to GeoTools level.
The details behind this request are reported in this JIRA:
https://osgeo-org.atlassian.net/browse/GEOS-9379
PSC members, would you please cast a vote?
Please, let me know if you have any questions.
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Geoserver-devel mailing list
Ian Turton
