[Geoserver-devel] Moving catalog loading _after_ the application context is loaded
recently I’ve been experimenting with loading the catalog from disk in a concurrent fashion (with a thread safe
DefaultCatalogFacade that I’ve been working on and that was briefly discussed in the last PSC meeting).
The main issue I’m facing trying to perform a parallel load is that the load happens while the Spring
application context is not fully loaded yet, and that in turn causes deadlocks.
This happens because parsing the xml files makes the security system do plugin searches
via GeoServerExtensions.beans(…) to decode passwords in xml files, with a parallel load that would
happen in a thread other than the one loading the app-context, and the dealock occurs because Spring
has a lock preventing multithreading during app-context startup.
So I was wondering, would it be possible to load the catalog after the app context startup instead?
Right now the only issue I’m aware of is GWC loading its own tile layers, but that could also be moved
after the startup sequence.
Anyone aware of other reasons?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I am not aware of any other issue; sounds like a great plan (and makes application startup more consistent for debugging).
On 14 January 2017 at 02:53, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Developer Access Program for Intel Xeon Phi Processors
Access to Intel Xeon Phi processor-based developer platforms.
With one year of Intel Parallel Studio XE.
Training and support from Colfax.
Order your platform today. http://sdm.link/xeonphi
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Jody Garnett
