[Geoserver-devel] Moving IOUtils to gs-platform
I have been recently looking into GEOS-7651, and in doing so discovered that most of the ResourceStore stuff, including FileSystemResource, lives in the gs-platform project.
IOUtils contains a bunch of usefull File and IO utilities, including a very thorough rename method. However, IOUtils is contained in the gs-main project, which has gs-platform as a dependency
FileSystemResouce is currently using the plain java File rename, leading to GEOS-7651.
It seems like it would be a good idea to have utility classes such as IOUtils as far upstream as possible (e.g. in gs-platform rather than gs-main). IOUtils current contains a couple of methods that depend on classes in gs-main (XStreamPersister related stuff, which could remain in gs-main), but everything else does not depend upon any geoserver classes.
I am aware that this is a substantial API change, and is definately not a change that is realistic to make on a short time scale, but it seems like something that would be valuable longer term.
A relatively safe approach would be copying the requisite portions to gs-platform and deprecating the gs-main version for 2.10, and actually removing the gs-main version in 2.11.
Any input or opinions? Any obvious reasons that this is a bad idea that I may have missed?
Torben
On Thu, Sep 8, 2016 at 6:50 PM, Torben Barsballe <
What if you extend IOUtils in main extend the one in platform, adding just
the extra methods? As far as I remember static class methods
can be called using a subclass reference... yep, the following compiles and
works:
public class TestInheritStatic {
    public static class Base {
        public static void hello() { System.out.println("hello");}
    public static class Derived extends Base {
    public static void main(String args) {
        Derived.hello();
If you deprecate the one in main please remove all references to it in the
geoserver code base, to avoid
creating tech debt in the process.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Good idea with the extends. Probably don’t really need to deprecate anything if we go that route.
And yes, if I were to move it I would make sure to do a full refactor, not just a manual move.
Torben
On Thu, Sep 8, 2016 at 9:59 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Sep 8, 2016 at 6:50 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
What if you extend IOUtils in main extend the one in platform, adding just the extra methods? As far as I remember static class methods
can be called using a subclass reference… yep, the following compiles and works:
public static void hello() { System.out.println(“hello”);}
Derived.hello();
If you deprecate the one in main please remove all references to it in the geoserver code base, to avoid
Ing. Andrea Aime
@geowolf
Technical Lead
