[Geoserver-devel] Moving to gt-property-ng - Final migration
After the latest batch of geotools changes, both geotools and geoserver will now work with gt-property-ng instead of gt-property (Barring a single test failure in AggregatingDataStore, for which a fix can be found here: https://github.com/geotools/geotools/pull/675).
In order to complete this change, we will be eliminating AbstractDataStore and gt-property.
In addition to PropertyDataStore, the Type Hiearchy of AbstractDataStore contains a number of other classes:
AbstractFileDataStore (gt-main)
ArrayDataStore (gt-main)
CollectionDataStore (gt-main)
MemoryDataStore (gt-main)
PropertyDataStore (docs & gt-property)
VPFFileStore (unsupported/gt-vpf)
VPFLibrary (unsupported/gt-vpf)
WFS_1_0_0_DataStore (unsupported/gt-wfs)
Some of these classes (MemoryDataStore in particular) are used by geotools core classes. If we want to eliminate AbstractDataStore these dependancies will have to be resolved.
Jody has suggested moving the contents of gt-property-ng to gt-property, so than downstream users will not have to update their dependancies.
After this change has been made, a few test cases in geoserver will need to be updated (More will need to be updated if we leave gt-property-ng where it is).
These are all fairly trivial changes, and include adding a method to one of the mocks, changing an instanceof test, and fixing a spelling issue. If gt-property-ng remains where it is, several other name-based tests will need to be updated, and a number of dependancies will need to be updated to use gt-property-ng.
Torben
On Thu, Jan 8, 2015 at 7:53 PM, Torben Barsballe <
and gt-property.
MemoryDataStore is actually used quite a bit, don't think we can just pull
it away. It will have to be migrated to content data store I assume?
Also, don't think we can eliminate a public base class like
AbstractDataStore without a deprecation cycle,
and the class is currently not deprecated.
To give a bit of courtesy to users (and really, just apply our usual
"important public class" phase out methodology),
AbstractDataStore should be deprecated and moved to gt-legacy, and removed
only in geotools 14
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Agreed, AbstractDataStore has a large number of supporting classes that can join it in deprecation.
On Thu, Jan 8, 2015 at 11:01 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Jan 8, 2015 at 7:53 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
MemoryDataStore is actually used quite a bit, don’t think we can just pull it away. It will have to be migrated to content data store I assume?
Also, don’t think we can eliminate a public base class like AbstractDataStore without a deprecation cycle,
To give a bit of courtesy to users (and really, just apply our usual “important public class” phase out methodology),
AbstractDataStore should be deprecated and moved to gt-legacy, and removed only in geotools 14
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Technical Lead | Boundless
jgarnett@anonymised.com
877-673-6436
@jodygarnett
Are we all in agreement to replace gt-property with gt-property-ng? Does anyone have any concerns?
Should the old gt-property implementation be completely eliminated, or moved to an unsupported module?
Torben
On Thu, Jan 8, 2015 at 11:46 AM, Jody Garnett <jgarnett@anonymised.com> wrote:
Jody Garnett
877-673-6436
@jodygarnett
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Jan 8, 2015 at 9:13 PM, Torben Barsballe <
If everything works in geotools and geoserver, I'd say we have a pretty
good test coverage and as
a result, no concerns.
Just keep an eye on the GeoServer WFS cite tests, the recent changes to
content data store might affect them
When I did the same for the shapefile module, I kept a shepefile-old in
unsupported for one release cycle,
just to be on the safe side, maybe someone out there is using it in a
different way, and some bugs might
still be around.
Ing. Andrea Aime
@geowolf
Technical Lead
The geoserver test fixes to support the migration are here: https://github.com/geoserver/geoserver/pull/877
Torben
On Thu, Jan 8, 2015 at 12:30 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Jan 8, 2015 at 9:13 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
If everything works in geotools and geoserver, I’d say we have a pretty good test coverage and as
Just keep an eye on the GeoServer WFS cite tests, the recent changes to content data store might affect them
When I did the same for the shapefile module, I kept a shepefile-old in unsupported for one release cycle,
just to be on the safe side, maybe someone out there is using it in a different way, and some bugs might
still be around.
Ing. Andrea Aime
@geowolf
Technical Lead
The pull request for the migration is here: https://github.com/geotools/geotools/pull/679
On Fri, Jan 9, 2015 at 3:25 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
On Thu, Jan 8, 2015 at 12:30 PM, Andrea Aime <andrea.aime@anonymised.com8…> wrote:
still be around.
Ing. Andrea Aime
@geowolf
Technical Lead
