[Geoserver-devel] Moving to servlet-api 3.0
To use new features in the servlet api (specifically HttpServletRequest.login to support delegating authentication from GeoServer to the container) the version would need to be bumped.
That means GeoServer won’t run on older containers like Tomcat 6 which is still supported by Apache.
Would that be an acceptable change for GeoServer?
Br,
Martin Andersson
On Wed, Nov 11, 2015 at 3:46 PM, Martin Andersson <
martin.andersson@anonymised.com> wrote:
That means GeoServer won't run on older containers like Tomcat 6 which is
I know of a fair number of people still running Tomcat 6 (to my surprise, I
might add).
Also, our bin/windows/osx bundles are running Jetty 6, which is really old,
but has been upgraded to version 9 on the development series only, that one
seems to support servlet 3 according to
https://en.wikipedia.org/wiki/Jetty_(web_server)
I think we can consider this as an option for the development series, but
not for stable (2.8.x) and maintenance (2.7.x).
Just my opinion though, let's hear the other devs
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
As someone who tried to do this recently I can offer some insight. The real work is updating our tests. We use a mock library (mock runner) for mocking up servlet api objects (requests, response, servlet context), etc… And I wasn’t able to upgrade to a version that supports a newer version of the servlet api spec (3.0 or 3.1). It wasn’t clear to me if mock runner is being well maintained anymore. I found a few open github issues about the topic that date back to 2013.
That said, spring has better and more up to date support for mocking those objects, so I recommend we move to that. Unfortunately that is a pretty far reaching change (albeit pretty mechanical), it’s just updating imports and then updating a few method calls that are different between mock runner and spring mock http. Basically it needs someone (or a group of people) to be gung-ho enough to go through all modules and make the updates. With some scripting / regex it might actually not be that bad but I never got that far.
$0.02
On Wed, Nov 11, 2015 at 7:56 AM, Andrea Aime <andrea.aime@anonymised.com…> wrote:
Geoserver-devel mailing list
On Wed, Nov 11, 2015 at 3:46 PM, Martin Andersson <martin.andersson@anonymised.com> wrote:
I know of a fair number of people still running Tomcat 6 (to my surprise, I might add).
Also, our bin/windows/osx bundles are running Jetty 6, which is really old, but has been upgraded to version 9 on the development series only, that one
seems to support servlet 3 according to https://en.wikipedia.org/wiki/Jetty_(web_server)
I think we can consider this as an option for the development series, but not for stable (2.8.x) and maintenance (2.7.x).
Just my opinion though, let’s hear the other devs
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Nov 11, 2015 at 6:20 PM, Justin Deoliveira <jdeolive@anonymised.com>
far.
Ah, I was thinking about it some time ago and had a half baked idea of
doing something like this:
* Drop mockrunner
* Implement new fresh java code in gs-main, but with the same package and
class name as the old mockrunner classes we were using
* Fill them delegating to the spring mock objects (or extending them)
* Finally tell the IDE to refactor those in a geoserver package
Sounds like it could be less work... but maybe not... I did not actually
check what would need to be done :-p
Ing. Andrea Aime
@geowolf
Technical Lead
