[Geoserver-devel] Moving wcs test coverages to data module
First, my motivation is to test rest config, the coverage and coverage store side of things. It would be handy if i could use the mock test setup.
So i would like to move the raster test data that is in wcs1_1 module to MockData in the data module.
I intend to keep all test setup the same, ie, not load coverages by default. Instead a new method to MockData called "addWellKnownCoverageTypes()". This method will have to invoked manually by a mock test case that wishes to load the raster data.
The only changes to wcs1_1 will be to WCSTestSupport, moving some static constants to MockData, and changing populateDataDirectory() to call through to the addWellKnownCoverageTypes() method.
Any objections?
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin Deoliveira ha scritto:
Any objections?
No objections whatsoever, this will help testing other modules
as well (raster support in wms, wps).
Andrea Aime
