[Geoserver-devel] Multiple CRS for a single Coverage
Hello Geoserver-Devel!
As part of an ongoing Geoserver related project I'm currently faced with adding a custom CRS to Geoserver for some of the data layers I will be serving. These layers will need to be queryable from either the custom CRS or EPSG:4326. Is there a way to assign two separate CRS's to a published layer or is every layer published with only one, and then all other incoming requests translated to the stored bounds? In either case, any examples demonstrating this procedure (either assigning a second CRS or performing the translation) would be deeply appreciated.
David Marks
When publishing a wms layer it can be viewed nand queried from any CRS geoserver supports. Vector data is transformed on the fly, raster dats is re sampled as required.
Is this a feature you missed or am I not understanding your question?
On Wed, Jun 3, 2015 at 12:14 PM Marks, David <David.Marks@anonymised.com> wrote:
As part of an ongoing Geoserver related project I’m currently faced with adding a custom CRS to Geoserver for some of the data layers I will be serving. These layers will need to be queryable from either the custom CRS or EPSG:4326. Is there a way to assign two separate CRS’s to a published layer or is every layer published with only one, and then all other incoming requests translated to the stored bounds? In either case, any examples demonstrating this procedure (either assigning a second CRS or performing the translation) would be deeply appreciated.
David Marks
Geoserver-devel mailing list
No, I understand that. The custom CRS I need to utilize does not exist within Geoserver however, so no build in transformations are known. If I cannot simply store a layer in a second coordiate space, how would I introduce a new translation/CRS??
David Marks
Sent: Wednesday, June 3, 2015 4:46 PM
To: Marks, David; Geoserver-devel
Subject: Re: [Geoserver-devel] Multiple CRS for a single Coverage
On Wed, Jun 3, 2015 at 12:14 PM Marks, David <David.Marks@anonymised.com<mailto:David.Marks@anonymised.com>> wrote:
David Marks
Geoserver-devel@lists.sourceforge.net<mailto:Geoserver-devel@anonymised.comrge.net>
On Fri, Jun 5, 2015 at 2:29 PM, Marks, David <David.Marks@anonymised.com>
Probably this way, assuming the projection math is actually supported by
GeoServer:
http://docs.geoserver.org/stable/en/user/advanced/crshandling/customcrs.html
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
