[Geoserver-devel] Multiple GeoServerPersister instances
I’m noticing multiple GeoServerPersister instances getting registered as CatalogListeners both in the GeoServerPersisterTest testcase and on application start up. It doesn’t seem to be breaking anything other than producing some warnings when combined with what I’m working on but my understanding is there should only be one instance.
Anyone have any idea what’s up? Is it supposed to be doing this?
Thread [main] (Suspended (breakpoint at line 1388 in CatalogImpl))
CatalogImpl.addListener(CatalogListener) line: 1388
SystemTestData.createCatalog() line: 286
SystemTestData.setUp() line: 123
GeoServerPersisterTest(GeoServerBaseTestSupport).doSetup() line: 148
NativeMethodAccessorImpl.invoke0(Method, Object, Object) line: not available [native method]
NativeMethodAccessorImpl.invoke(Object, Object) line: 57
DelegatingMethodAccessorImpl.invoke(Object, Object) line: 43
Method.invoke(Object, Object…) line: 606
FrameworkMethod$1.runReflectiveCall() line: 47
FrameworkMethod$1(ReflectiveCallable).run() line: 12
FrameworkMethod.invokeExplosively(Object, Object…) line: 44
RunBefores.evaluate() line: 24
RunAfters.evaluate() line: 27
RunRules.evaluate() line: 20
BlockJUnit4ClassRunner(ParentRunner).runLeaf(Statement, Description, RunNotifier) line: 271
BlockJUnit4ClassRunner.runChild(FrameworkMethod, RunNotifier) line: 70
BlockJUnit4ClassRunner.runChild(Object, RunNotifier) line: 50
ParentRunner$3.run() line: 238
ParentRunner$1.schedule(Runnable) line: 63
BlockJUnit4ClassRunner(ParentRunner).runChildren(RunNotifier) line: 236
ParentRunner.access$000(ParentRunner, RunNotifier) line: 53
ParentRunner$2.evaluate() line: 229
RunBefores.evaluate() line: 26
BlockJUnit4ClassRunner(ParentRunner).run(RunNotifier) line: 309
JUnit4TestMethodReference(JUnit4TestReference).run(TestExecution) line: 50
TestExecution.run(ITestReference) line: 38
RemoteTestRunner.runTests(String, String, TestExecution) line: 467
RemoteTestRunner.runTests(TestExecution) line: 683
RemoteTestRunner.run() line: 390
RemoteTestRunner.main(String) line: 197
owns: ConcurrentHashMap<K,V> (id=90)
owns: Object (id=91)
DefaultGeoServerLoader.loadCatalog(Catalog, XStreamPersister) line: 50
DefaultGeoServerLoader(GeoServerLoader).postProcessBeforeInitialization(Object, String) line: 112
GeoServerLoaderProxy.postProcessBeforeInitialization(Object, String) line: 58
DefaultListableBeanFactory(AbstractAutowireCapableBeanFactory).applyBeanPostProcessorsBeforeInitialization(Object, String) line: 394
DefaultListableBeanFactory(AbstractAutowireCapableBeanFactory).initializeBean(String, Object, RootBeanDefinition) line: 1448
DefaultListableBeanFactory(AbstractAutowireCapableBeanFactory).doCreateBean(String, RootBeanDefinition, Object) line: 519
DefaultListableBeanFactory(AbstractAutowireCapableBeanFactory).createBean(String, RootBeanDefinition, Object) line: 456
AbstractBeanFactory$1.getObject() line: 294
DefaultListableBeanFactory(DefaultSingletonBeanRegistry).getSingleton(String, ObjectFactory) line: 225
DefaultListableBeanFactory(AbstractBeanFactory).doGetBean(String, Class, Object, boolean) line: 291
DefaultListableBeanFactory(AbstractBeanFactory).getBean(String) line: 193
DefaultListableBeanFactory.preInstantiateSingletons() line: 607
GeoServerTestApplicationContext(AbstractApplicationContext).finishBeanFactoryInitialization(ConfigurableListableBeanFactory) line: 925
GeoServerTestApplicationContext(AbstractApplicationContext).refresh() line: 472
GeoServerPersisterTest(GeoServerSystemTestSupport).setUp(SystemTestData) line: 213
GeoServerPersisterTest(GeoServerSystemTestSupport).setUp(TestData) line: 158
GeoServerPersisterTest(GeoServerBaseTestSupport).doSetup() line: 150
Kevin Smith
Junior Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
It is not supposed to be doing this, although from your stack traces I cannot determine if SystemTestData or DefaultGeoServerLoader should own the responsibility. My money would be on DefaultGeoServerLoader.
Do you know what classes are registering persisters during normal application use? Or did I not understand you…
Kevin Smith
+1-778-785-7459
@boundlessgeo
Jody Garnett
There is a bit of tricky logic when it comes to registering the persister during startup, it is used for a couple of purposes, one being to migrate from older configuration, you’ll see code that adds it, does something, and then removes it after. Possible something has creeped in but yes, there should only be one persister registered at any given time.
Kevin Smith
+1-778-785-7459
@boundlessgeo
“Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos.
Get unparalleled scalability from the best Selenium testing platform available
Simple to use. Nothing to install. Get started now for free.”
http://p.sf.net/sfu/SauceLabs
Geoserver-devel mailing list
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
can you describe how it is used to migrate an older configuration? Is it a case of migration modifying the data structure and depending on the persister to write out the change in a “modern” form? Looking over at Kevin’s debugger we are certainly seeing two GeoServerPersisters in the list of listeners.
Jody Garnett
On Fri, May 16, 2014 at 5:16 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Kevin Smith
+1-778-785-7459
@boundlessgeo
Justin Deoliveira
@j_deolive
The way it works is that when GeoServer starts up and recognizes a pre 2.x data directory it adds the persister before reading it. That way while it reads it and populates the catalog all the objects are serialized out in the current format.
This differs from a normal start up in which the persister is not added until after the entire catalog/config contents is read.
On Fri, May 16, 2014 at 10:31 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Justin Deoliveira
@j_deolive
Jody Garnett
Kevin Smith
+1-778-785-7459
@boundlessgeo
Justin Deoliveira
@j_deolive
So it is likely that our test cases use a “pre 2.x” data directory then - is it worth fixing that?
Can we unregister the persister after it is done reading … or were you expecting that to already be done…
Jody Garnett
On Mon, May 19, 2014 at 11:37 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Justin Deoliveira
@j_deolive
Jody Garnett
Kevin Smith
+1-778-785-7459
@boundlessgeo
Justin Deoliveira
@j_deolive
IF the test case is extending from the old GeoServerAbstractTestSupport base class then it would be using a pre 2.x data directory. If it extends from GeoServerSystemTestSupport then it would be using a post 2.x version.
On Tue, May 20, 2014 at 6:56 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Justin Deoliveira
@j_deolive
Jody Garnett
Justin Deoliveira
@j_deolive
Jody Garnett
Kevin Smith
+1-778-785-7459
@boundlessgeo
Justin Deoliveira
@j_deolive
It extends GeoServerSystemTestSupport, and the data directory I used when testing a regular start up was a copy of data/release.
Kevin Smith
+1-778-785-7459
@boundlessgeo
Justin Deoliveira
@j_deolive
Jody Garnett
Justin Deoliveira
@j_deolive
Jody Garnett
Kevin Smith
+1-778-785-7459
@boundlessgeo
Justin Deoliveira
@j_deolive
