Is the war goal for mvn supposed to work? It ends up with error(s)
about web.xml missing form various places.
Jira worthy?
Alex
Jira worthy?
Alex
it is supposed to work just fine. What errors are you getting?
about web.xml missing form various places.Jira worthy?
Alex-------------------------------------------------------------------------
opinions on IT & business topics through brief surveys-and earn cash
Geoserver-devel mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-devel!DSPAM:1004,45e714c4131732207481331!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Only relevant snippet:
[INFO] Generating war
/home/apetkov/workspace/geoserver-1.5.x/geoserver/maven/merger/target/merger-1.5.0-RC1.war
[ERROR] BUILD ERROR
[INFO] Error assembling WAR: Deployment descriptor:
/home/apetkov/workspace/geoserver-1.5.x/geoserver/maven/merger/target/merger-1.5.0-RC1/WEB-INF/web.xml
does not exist.
This is after I manually copied the web.xml to a few other locations.
Finally got sick of it.
Alex
Are you running it from the web/ module?
It will work from there, using the 'release' config: mvn -DconfigId=release war:war
Brent Owens
(The Open Planning Project)
Only relevant snippet:[INFO] Generating war
[ERROR] BUILD ERROR
does not exist.This is after I manually copied the web.xml to a few other locations.
Finally got sick of it.Alex
I believe brent is correct. You are running it from the root module so
it is executing for every single module, and since not every module is a
web based module it will fail. Executing from web as brent says should
fix it.
Perhaps we should make this more clear in the maven quickstart.
-Justin
-DconfigId=release war:warBrent Owens
/home/apetkov/workspace/geoserver-1.5.x/geoserver/maven/merger/target/merger-1.5.0-RC1.war[INFO]
[ERROR] BUILD ERROR
[INFO]
/home/apetkov/workspace/geoserver-1.5.x/geoserver/maven/merger/target/merger-1.5.0-RC1/WEB-INF/web.xmldoes not exist.
share your
https://lists.sourceforge.net/lists/listinfo/geoserver-devel!DSPAM:1004,45e719f4136991995013331!
Justin Deoliveira
fix it.Perhaps we should make this more clear in the maven quickstart.
-Justin
To be honest, I didn't look there, sorry (shame).
Alex
No problem, since it is not there :). I am going to add another section
to the quickstart titled "Building a Web Archive (war)".
-Justin
-Justin
Alex
https://lists.sourceforge.net/lists/listinfo/geoserver-devel!DSPAM:1004,45e71c71139811804284693!
Justin Deoliveira
