[Geoserver-devel] MVN repo.boundlessgeo having problems?
http://repo.boundlessgeo.com/main seems not working anymore.
Can someone take a look?
-A.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via Poggio alle Viti 1187
mob: +39 331 6233686
Hi Alessio, there is a related debate few days ago with explications in this mailing list.
You can check the replies for…
[Geoserver-devel] Maven repo of boundlessgeo working?Alvaro
De: Alessio Fabiani <alessio.fabiani@anonymised.com68…>
Para: Geoserver-devel geoserver-devel@lists.sourceforge.net; “geotools-devel@anonymised.comsts.sourceforge.netgeotools-devel@lists.sourceforge.net
Enviado: Lunes 26 de octubre de 2015 11:53
Asunto: [Geoserver-devel] MVN repo.boundlessgeo having problems?
-A.
@alfa7691
Geoserver-devel mailing list
I just did a frech clone of geotools 14.x which is hitting repo.boundlessgeo repo and I confirm that this is NOT working.
De: Alessio Fabiani <alessio.fabiani@anonymised.com.1268…>
Para: Geoserver-devel <geoserver-devel@lists.sourceforge.net>; “geotools-devel@lists.sourceforge.net” <geotools-devel@anonymised.comrge.net>
-A.
@alfa7691
Geoserver-devel@anonymised.comsourceforge.net
@alfa7691
UPDATE: unless there is some DNS issue somewhere, the only way to compile old projects is to replace
http://repo.boundlessgeo.com/main/
with
http://boundless.artifactoryonline.com/main/
into the pom.xml
On Mon, Oct 26, 2015 at 12:46 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
@alfa7691
@alfa7691
De: Alessio Fabiani <alessio.fabiani@anonymised.com>
Para: Geoserver-devel <geoserver-devel@anonymised.comceforge.net>; “geotools-devel@lists.sourceforge.net” <geotools-devel@lists.sourceforge.net>
-A.
@alfa7691
Same issue here in the UK
Ian
On 26 October 2015 at 12:01, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
with
into the pom.xml
GeoTools-Devel mailing list
GeoTools-Devel@anonymised.coms.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
@alfa7691
@alfa7691
Para: Geoserver-devel <geoserver-devel@lists.sourceforge.net>; “geotools-devel@lists.sourceforge.net” <geotools-devel@lists.sourceforge.net>
-A.
@alfa7691
Ian Turton
Morning Alessio (and all).
Got an update for everyone … all last week we normal, under 50k requests a day with one spike over that line. A spike of over 300k today took things offline.
So I have two solutions:
  • short term (i.e. now) we will update pom.xml to point towards artifiactory on all branches
  • long term we are setting up redundant, autoscaling, load balanced artifactory instance on AWS
On 26 October 2015 at 04:53, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
-A.
@alfa7691
Jody Garnett
I have updated the geotools poms to point to artifactory. Waiting on the ares builds to verify the fix.
Torben
On Mon, Oct 26, 2015 at 8:52 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
-A.
@alfa7691
GeoTools-Devel@lists.sourceforge.net
GeoTools ares build finished. The artifactory repo is working, but we are getting build failures in 13.x and 14.x.
Looks like a test failure in Render for 13.x and a Documentation build failure in 14.x.
Torben
On Mon, Oct 26, 2015 at 11:46 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Jody Garnett
-A.
@alfa7691
On Mon, Oct 26, 2015 at 9:26 PM, Torben Barsballe <
failure in 14.x.
The compile failure on 14.x might be Ian's recent backport of a fix on
master:
https://github.com/geotools/geotools/pull/1016
The Travis build apparently already complained on the pull request, with
the same error:
https://travis-ci.org/geotools/geotools/builds/87485009
The doc failure (warning being treated as failures) could be due to this
Frank's commit (most recent commit on the file):
https://github.com/geotools/geotools/commit/180b3f7ea00d6838a778f1390d60ada17a24362f
I've cc'ed both of them
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
OK I’ve reverted that PR but it builds on my machine so I assumed the travis fail was due to the repo issue, I’ll check some more later.
Ian
On 26 October 2015 at 20:49, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, Oct 26, 2015 at 9:26 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
The compile failure on 14.x might be Ian’s recent backport of a fix on master:
The Travis build apparently already complained on the pull request, with the same error:
The doc failure (warning being treated as failures) could be due to this Frank’s commit (most recent commit on the file):
I’ve cc’ed both of them
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
On Tue, Oct 27, 2015 at 10:03 AM, Ian Turton <ijturton@anonymised.com> wrote:
OK I've reverted that PR but it builds on my machine so I assumed the
travis fail was due to the repo issue, I'll check some more later.
Thanks!
Ing. Andrea Aime
@geowolf
Technical Lead
