this message is primarily for Andrea I guess, since he setted up the reporting
plugin in pom.xml.
I was trying to get a geoserver site generated by maven, after a couple
failures and retries doing "mvn site -U" I got it running. Failures seemed to
have to be with ibiblio reliability.
After mvn site finished, the generated page in target/site/index.html contains
hyperlinks to the different modules pages, but they don't seem to be
generated (i.e. target/site/wms/index.html pointed by the "Web Map Service
Module" link doesn't exists)
Do you know if I am doing something wrong or is it just missconfigured or
something?
cheers,
Gabriel Roldán (groldan@anonymised.com)
Axios Engineering (http://www.axios.es)
Tel. +34 944 41 63 84
Fax. +34 944 41 64 90
btw, the docs are generated in each module's target/site, just not aggregated
on the main project's target directory, so I guess it is alright and one have
to copy them if need to publish the aggregated docs?
On Wednesday 23 August 2006 19:07, Gabriel Roldán wrote:
reporting plugin in pom.xml.
to have to be with ibiblio reliability.
contains hyperlinks to the different modules pages, but they don't seem to
be generated (i.e. target/site/wms/index.html pointed by the "Web Map
Service Module" link doesn't exists)
something?
cheers,
Gabriel Roldán ha scritto:
this message is primarily for Andrea I guess, since he setted up the reporting plugin in pom.xml.
I was trying to get a geoserver site generated by maven, after a couple failures and retries doing "mvn site -U" I got it running. Failures seemed to have to be with ibiblio reliability.
After mvn site finished, the generated page in target/site/index.html contains hyperlinks to the different modules pages, but they don't seem to be generated (i.e. target/site/wms/index.html pointed by the "Web Map Service Module" link doesn't exists)
Do you know if I am doing something wrong or is it just missconfigured or something?
No, I don't think so. The only way I've found to get a site generated with
proper links is to deploy it on a local folder... otherwise I get the
same result as you.
Reporting is mainly a copy of gt2 with some small modifications, and the
problem is there in gt2 as well.
I just never invested more time trying to understand or fix it.
ah, ok.
thanks for the reply
Gabriel
> Hi,
> something?
same result as you.
