www.g2o.com:8000/geoserver/
Error 404 - Not Found.
No context on this server matched or handled this request.
Contexts known to this server are:
WebApplicationContext[/geoserver,GeoServer]
HTTP ERROR: 500 Unable+to+compile+class+for+JSP%0A%0AAn+error+occurred+at+line%3A+%2D1+in+the+jsp+file%3A+null%0A%0AGenerated+servlet+error%3A%0A++++%5Bjavac%5D+Compiling+1+source+file%0A%0A%0A
RequestURI=/geoserver/
Powered by Jetty://
this is the command line errors i get
16:30:15.545 EVENT Exception: : Error running javac compiler
at org.apache.tools.ant.taskdefs.compilers.DefaultCompilerAdapter.executeExternalCompile(DefaultCompilerAdapter.java:446)
at org.apache.tools.ant.taskdefs.compilers.JavacExternal.execute(JavacExternal.java:43)
at org.apache.tools.ant.taskdefs.Javac.compile(Javac.java:936)
at org.apache.tools.ant.taskdefs.Javac.execute(Javac.java:758)
at org.apache.jasper.compiler.Compiler.generateClass(Compiler.java:317)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:370)
at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:473)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:190)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:295)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:241)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:358)
at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:294)
at org.mortbay.jetty.servlet.Dispatcher.dispatch(Dispatcher.java:222)
at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:135)
at org.mortbay.jetty.servlet.Default.handleGet(Default.java:293)
at org.mortbay.jetty.servlet.Default.service(Default.java:208)
at org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:342)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:122)
at org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:334)
at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:286)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:567)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1807)
at org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplicationContext.java:525)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1757)
at org.mortbay.http.HttpServer.service(HttpServer.java:879)
at org.mortbay.http.HttpConnection.service(HttpConnection.java:790)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:961)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:807)
at org.mortbay.http.SocketListener.handleConnection(SocketListener.java:197)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:276)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:511)
Caused by: java.io.IOException: java.io.IOException: javac: not found
at java.lang.UNIXProcess.<init>(Unknown Source)
at java.lang.ProcessImpl.start(Unknown Source)
at java.lang.ProcessBuilder.start(Unknown Source)
at java.lang.Runtime.exec(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.apache.tools.ant.taskdefs.Execute$Java13CommandLauncher.exec(Execute.java:831)
at org.apache.tools.ant.taskdefs.Execute.launch(Execute.java:436)
at org.apache.tools.ant.taskdefs.Execute.execute(Execute.java:450)
at org.apache.tools.ant.taskdefs.compilers.DefaultCompilerAdapter.executeExternalCompile(DefaultCompilerAdapter.java:443)
... 33 more
--- Nested Exception ---
16:30:15.656 WARN!! Exception for /geoserver/
org.apache.jasper.JasperException: Unable to compile class for JSP
An error occurred at line: -1 in the jsp file: null
Generated servlet error:
[javac] Compiling 1 source file
at org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:130)
at org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:293)
at org.apache.jasper.compiler.Compiler.generateClass(Compiler.java:353)
Rodrick K, Smith
