[Geoserver-devel] Need advice on managing resources for WPS in Geoserver
Hi All,
We are attempting to integrate a WPS service into Geoserver 2.7.0 and have some issues around resource management.
Briefly, our WPS Process involves,
  • Implementing a GeoServerProcess that uses the execute() method to return a class deriving from RawData.
  • Implementing the RawData.getInputStream() method to return an InputStream object. This object holds refs to a Geotools transaction object and a jdbc connection taken from a Geotools jdbcdatastore. These resources are used to consume and transform data - which is returned via calls on the InputStream’s read() methods.
We found that,
  • During synchronous WPS calls, if the remote client prematurely terminates the connection, there is no corresponding call back on the InputStream’s close() method. Without this notification we are unable to properly cleanup the geotools transaction and jdbc connection resources.
  • As soon as the InputStream is returned to the WPS executor, the job is marked as complete, even though it may take many hours to process and stream all the data. Additionally, any new WPS jobs are run immediately without respecting queue limits.
With the above issues in mind, we modified our approach to use a FileOutputStream created via resourceManager.getOutputResource(). The prevents the WPS job from being prematurely marked as complete until all data is written to the file. However it’s not our preferred choice for web-browsers since there’s no indication of any connection/download activity.
We also used the ProgressListener to monitor job state, by testing the progressListener.isCanceled() while processing. However we noticed,
  • That if the remote client disconnects we still don’t get notification of completion via the ProgressListener.
A couple of other minor issues,
  • timeouts begin from the time the job is queued, not the time the job run is started.
  • It’s not possible to set the max synchronous jobs to zero via the GUI as an indirect way to disable synchronous WPS jobs
Any advice would be greatly appreciated,
Julian
University of Tasmania Electronic Communications Policy (December, 2014).
This email is confidential, and is for the intended recipient only. Access, disclosure, copying, distribution, or reliance on any of it by anyone outside the intended recipient organisation is prohibited and may be a criminal offence. Please delete if obtained in error and email confirmation to the sender. The views expressed in this email are not necessarily the views of the University of Tasmania, unless clearly intended otherwise.
On Tue, Jun 2, 2015 at 10:37 AM, Julian Atkinson <j.f.c.atkinson@anonymised.com
wrote:
Hi All,
    - Implementing a GeoServerProcess that uses the execute() method to
    - Implementing the RawData.getInputStream() method to return an
InputStream's read() methods.
We found that,
- During synchronous WPS calls, if the remote client prematurely
InputStream's close() method. Without this notification we are unable to
Sounds like a bug. Please open a ticket, and if you can, follow with a pull
request to solve the issue.
- As soon as the InputStream is returned to the WPS executor, the job is
The queue is just for the "execute" phase. If you can change the code so
that it also does also the encoding in the execute thread, that would be
appreciated.
data is written to the file. However it's not our preferred choice for
web-browsers since there's no indication of any connection/download
activity.
Marked as complete... where? In the WPS protocol, or in the status store?
- That if the remote client disconnects we still don't get notification of
Same as above, ticket and pull request welcomed. Mind though, a client
disconnection cannot be determined as it happens,
the servlets only tell us about the disconnection via an exception thrown
as we try to write the output on the response output stream.
- timeouts begin from the time the job is queued, not the time the job
run is started.
Yes, I can see that... does not seem like it's easy to change that though,
we have nothing marking the
actual execution beginning... well, unless we wrapped the process with
something that notifies the MaxExecutionTimeListener
and then cascades the execute call. It's probably the less painful way.
Maybe this wrapper could also be a way to push the encoding in the
execution thread pool.
- It's not possible to set the max synchronous jobs to zero via the GUI
This is indeed not possible, and not formally correct either: as far as I
know, there is no way to communicate the client that a process
cannot be executed in synchronous mode, so denying it would probably be a
protocol violation.
I can see how it's desirable though, some processes are just running for
too much time to be usable in synch mode, but having a simple
blanket statement that no process should be run in synch mode is too
restrictive.
I'd try to add a per process setting instead.
Julian
intended otherwise.
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks for your help Andrea,
The queue is just for the “execute” phase. If you can change the code so that it also does also the encoding in the execute thread, that would be appreciated.
We re-arranged our code to block in the execute phase with our second implementation (generating the complete response and writing it to file storage, before returning from execute).
The apparent limitation is that the execute() method is also responsible for returning the RawData interface that supplies the InputStream which the wps extension code uses to return the response back to the client.
This prevents any streaming of buffered content while it is being generated in a synchronous context - even if we use separate producer and consumer threads. Instead the wps execution IO workflow seems to be organized around discreet jobs. Is that an accurate description of the behavior?
Julian
Julian
On Wed, Jun 3, 2015 at 10:07 AM, Julian Atkinson <j.f.c.atkinson@anonymised.com
appreciated.
behavior?
If it is, I don't understand it :slight_smile:
As far as I know streaming is possible, but it will happen in a thread
other than the ones in the pool, thus dodging the concurrent execution
limits
Ing. Andrea Aime
@geowolf
Technical Lead
Hi All,
Andrea advised that I should discuss code features/workarounds that we developed to address issues in the mailing list.
https://github.com/geoserver/geoserver/pull/1189
This PR provides an option to disable synchronous WPS requests via the GUI admin panel.
For our plugin - a template driven netcdf encoder with cql support - we would ideally have preferred synchronous+streaming behavior since that would replicate our already successfully developed http service while adding the wps protocol-support deemed necessary to satisfy an end-user contract.
However, we determined that fixing the resource leaks involving geotools transactions and gt store jdbc connections was too high-risk for us to tackle. As it stands, we rely on the above code to disable asynchronous support in production, to avoid an http client
accidently initiating async actions that create geoserver instability.
https://github.com/geoserver/geoserver/pull/1188
Changes the wps execution limit to apply only to job execution time. Existing behavior that includes both queue and execution time is maintained using the totalTime attributes.
Regards
Julian
From: andrea.aime@anonymised.comandrea.aime@anonymised.com on behalf of Andrea Aime <andrea.aime@anonymised.com…1268…>
Sent: Wednesday, June 3, 2015 6:13 PM
To: Julian Atkinson
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Need advice on managing resources for WPS in Geoserver
On Wed, Jun 3, 2015 at 10:07 AM, Julian Atkinson <j.f.c.atkinson@anonymised.com> wrote:
If it is, I don’t understand it :slight_smile:
As far as I know streaming is possible, but it will happen in a thread other than the ones in the pool, thus dodging the concurrent execution limits
Ing. Andrea Aime
@geowolf
Technical Lead
asynchronous should read synchronous. Sorry for the confusion.
Sent: Thursday, September 24, 2015 8:22 AM
To: Andrea Aime
Hi All,
Regards
Julian
To: Julian Atkinson
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Sep 24, 2015 at 12:22 AM, Julian Atkinson <
Hi All,
admin panel.
I have seen the need to selectively disallow sync requests for specific
processes, this one goes further and disallows synch requests completely.
On a general WPS server this does not make sense, as there are many service
WPSs which are fast and small (e.g., JTS based ones),
but I guess you're restricting your consideration to one that serves one
single process, your custom one.
This change makes the WPS non compliant, as there is no way to advertise a
process cannot be called in a synch way, and in particular,
it makes the WPS fully non compliant (no process can be called anymore by a
standard client).
While I agree on the need for specific processes that are geared towards
large computations and known to take a lot of time, I'm skeptical
on a flag that disables asynch requests at the global level.
I also recognize nobody forces the admins to check that flag, but
personally I would be much more comfortable with a per process flag instead.
Can other core developers share an opinion on this topic?
contract.
If there are leaks you should report them. Unless it's your process that's
causing the leaks to start with of course.
Ing. Andrea Aime
@geowolf
Technical Lead
Been following this thread but not in position to comment, recommend discussion on standards@…1503….
Ideally we could introduce something similar to ProcessDescription statusSupported (which indicates if async is supported), so a “statusRequired” could indicate if async is mandatory.
Short term I see/understand the need - and think it is best met with a prompt service exception.
How to advertise the limitation in the GetCapabilities document is another story - here are some ideas:
a) use a keyword (i.e. informal convention processes marked with a “statusRequired” keyword can only be used async)
b) use a metadata URI (i.e. could make it a formal convention)
c) If you look at WPS 2.0 you may be able to define a role for processes that can only be used async.
On 26 September 2015 at 02:18, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
On Thu, Sep 24, 2015 at 12:22 AM, Julian Atkinson <j.f.c.atkinson@anonymised.com> wrote:
Hi All,
I have seen the need to selectively disallow sync requests for specific processes, this one goes further and disallows synch requests completely.
On a general WPS server this does not make sense, as there are many service WPSs which are fast and small (e.g., JTS based ones),
but I guess you’re restricting your consideration to one that serves one single process, your custom one.
This change makes the WPS non compliant, as there is no way to advertise a process cannot be called in a synch way, and in particular,
it makes the WPS fully non compliant (no process can be called anymore by a standard client).
While I agree on the need for specific processes that are geared towards large computations and known to take a lot of time, I’m skeptical
I also recognize nobody forces the admins to check that flag, but personally I would be much more comfortable with a per process flag instead.
If there are leaks you should report them. Unless it’s your process that’s causing the leaks to start with of course.
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks for the comments. This is reasonable and I voiced the same arguments here myself. I’ll close the PR.
Sent: Sunday, September 27, 2015 3:13 AM
To: Andrea Aime
Cc: Julian Atkinson; geoserver-devel@lists.sourceforge.net
Been following this thread but not in position to comment, recommend discussion on standards@anonymised.com.
Jody Garnett
Hi All,
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks to Craig Jones for fixing the WPS resource leaks indicated by closing the InputStream after use,
https://github.com/geoserver/geoserver/pull/1337/files
Could I get some comments on,
https://github.com/geoserver/geoserver/pull/1188.
The current timeout behavior includes the time that the job has sat idle in the queue. This means that a long-running wps job can cause subsequent jobs to be evicted from the queue before they get a chance to start.
The PR enables a wps administrator to further set a job timeout that only checks for the time that the job has actually been running.
Our use case is to avoid end-users from submitting long-running WPS jobs that will cause other users’ jobs to fail.
From: Julian Atkinson j.f.c.atkinson@anonymised.com
Sent: Wednesday, September 30, 2015 7:13 AM
To: Jody Garnett; Andrea Aime
To: Andrea Aime
Jody Garnett
Hi All,
Ing. Andrea Aime
@geowolf
Technical Lead
