Hi all, during the GSOC 2011 I am working on this issue..
http://jira.codehaus.org/browse/GEOS-4554
I plan to split the architecture into two components, a user/group
management and a role authority. As an example, it should be possible
to get user/group info form the OS or a Database and storing roles in
property files. Many combinations are possible.
At the moment, we have a file
GEOSERVER_DATA_DIR/security/users.properties
with the following syntax
user=password,role1,....rolen,[enabled | disabled ]
This gives me headaches because password and enabled status belong to
user/group management while the roles belong to the role authority.
For a clean architecture I need 6 files
users.properties // user attributes without roles
groups.properties // group attributes without roles
roles.properties // roles
user_group.properties // "belongs to" relationship
user_roles.properties // "user has roles" relationship
group_roles.properties // "group has roles" relationship
An idea is to put these file in its own subdir
GEOSERVER_DATA_DIR/security/propertybased/*
The migration would be the following:
On first start, read the file
GEOSERVER_DATA_DIR/security/users.properties , create the directoy
hierarchy and new files, migrate, write a migration message in the log
and inform the admin that he can remove the old user.properties.
On the following starts, if
GEOSERVER_DATA_DIR/security/users.properties exists, I will write a
warning in the log to remove that file, since it is no longer used,
but contains passwords.
Opinions ?
This message was sent using IMP, the Internet Messaging Program.
