Hi Niels,
cannot comment on the pull request contents, but just in case you’re not aware,
we’re in feature freeze for the 2.11-RC1 release, new features will have to wait
for the master branch to switch to 18-snapshot/2.12-snapshot to be merged
On Wed, Mar 1, 2017 at 11:43 AM, Niels Charlier <niels@anonymised.com918…> wrote:
Hello Simone, Daniele,
I have made two pull requests with the aim of supporting “runtime” as an
additional dimension in netcdf-java:
The first is in the netcdf-java module itself:
https://github.com/geotools/geotools/pull/1472
Rather than just adding runtime to the supported time and elevation, it
is implemented in such a way that the VariableAdapter is now generalised
for any number of dimensions, which is something I discussed months ago
with Daniele and I thought it was a very good idea.
The second is in geoserver, which supports parsing custom dimensions to
Date (or other data types) before sending them to the geotools store,
rather than always sending them as a String:
https://github.com/geoserver/geoserver/pull/2117
If you could have a look at these, that would be great. Thanks in advance.
Kind Regards
Niels
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
GeoTools-Devel mailing list
GeoTools-Devel@anonymised.comsourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
