[Geoserver-devel] New 2.10.x build keeps on failing on vectortiles
From the logs:
[ERROR] Failed to execute goal on project gs-release: Could not resolve dependencies for project org.geoserver.community:gs-release:jar:2.10-SNAPSHOT: Could not find artifact org.geoserver.community:gs-vectortiles:jar:2.10-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) → [Help 1]
[ERROR]
Hmmm…as far as I can tell the build fails because the vector tiles module
is not actually part of the communityRelease profile:
https://github.com/geoserver/geoserver/blob/master/src/community/pom.xml#L163
Yep, not there… this also suggest that whoever got a nightly build so far, grabbed
an old jar that ended up on the build server by some other way…
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
As noted, this affects nightly builds; looks like the 2.9.x vectortiles jars are from December.
I have pushed a fix to master. When I confirm it builds succesfully, I will backport as appropriate.
Torben
On Sat, Apr 30, 2016 at 5:01 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
From the logs:
[ERROR]
Ing. Andrea Aime
@geowolf
Technical Lead
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z
Geoserver-devel mailing list
