I’d like to create 2 new test modules:
At the moment app-schema-test suite only tests with properties files; these new modules are empty placeholders for running app-schema-test suite with online mode (oracle and postgis).
This would enable the tests to run with real database backend, therefore testing Niels’ joining support and bug fixes that occur with specific database type only.
The purpose is so we can have separate modules running the same tests (with different parameters) in our internal buildbot, with separate results etc.
Code changes to support the tests to run online have already been committed.
The modules will only be built when “app-schema-online-test” profile is enabled. Does anyone mind if I do this?
Rini
On Mon, Feb 13, 2012 at 5:29 AM, Rini.Angreani@anonymised.com wrote:
I certainly don’t, more testing == good
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Thanks Andrea. I will go ahead with this shortly.
View this message in context: http://osgeo-org.1560.n6.nabble.com/new-app-schema-test-modules-tp4463935p4464410.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
