I’d like to introduce a Checkstyle check that verifies lines are not too deeply nested.
The Google format we are using is indenting excessively long lines that are overflowing on the next line 8 chars instead of 4,
I believe as a way to discourage too deep nesting.
However, we have a lot of old code that has been reformatted blindly, and we have situations in the code like these:
The first one can be easily fixed using Objects.hashCode(…) while the second is in need of a bit of expression splitting.
There are other egregious cases around, mostly due to excessive usage of nested classes (e.g., Wicket GUI code).
I’ve found a simple checkstyle configuration can spot all of them:
This should make the code overall more readable, and stop new too deeply nested bits to show up in the codebase.
Opinions?
Here we go, for the GeoTools code, limiting the start line to column 65 (leaves 35 chars to write a bit of code before wrapping happens): https://github.com/geotools/geotools/pull/3724
Did not try to go down to 60 but… it’s likely quite a bit of extra effort, I started with 80 and went down, each step required more code
changes to enforce the rule.
Andrea Aime
