Dear all,
I’m writing here to contribute a new cov-json community module, implementing the CoverageJson format that allows representing coverage grids as well as time series with simple json.
For example, it can be used by clients requesting WCS getCoverages against a temporal coverage on a single x,y coordinate (that would be called a PointSeries).
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
