[Geoserver-devel] New Community Module : External Web Authentication
Dear List,
Introduction and Background:
This email is a proposal for a new Authentication module that can be used to integrate GeoServer with external HTTP Authentication endpoints. GeoServer already provides authentication via JDBC, LDAP. The new proposed module works similarly, as it queries an external URL to authenticate the user. There are multiple scenarios where GeoServer is deployed in environments having centralized authentication services. This community module is aimed at simplifying and streamlining this type integration.
Authentication :
The external HTTP endpoint will be configurable through known place holders {user} and {passowrd}. (e.g http://localhost:5000/auth?u={user}&p={password}. These placeholders will be substituted with credentials.
Authorization Options :
For services responding with roles, the module will parse the roles in response using a configured Regex expression.
Alternatively, an existing Role service can be selected to authorize a successfully authenticated user. By default the system level Role service will be used.
Looking forward to your valuable feedback and suggestions
regards,
Imran
– I.R
+1 from me
Ian
(attachments)
Ian Turton
+0
(attachments)
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
+0
(attachments)
Nuno Oliveira
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
